Mivec modification, and results on stock bottom end.
Old Oct 28, 2013 | 06:46 PM
mrfred's Avatar
Originally Posted by JohnBradley
Since the stock range is -1.2 to +28.8* I would say that for the most part modding it is unneeded unless you were looking for more down low.
I'm kinda thinking the other way around. Would be interesting to see what -6 deg does at peak power for a kill mode tune where emap is way higher than imap. Or perhaps the better approach is messing with the exhaust cam timing?
Old Oct 28, 2013 | 07:10 PM
211Ratsbud's Avatar
I'm afraid to mess with the ecu ign timing reference. Would it be as simple as 1=2 2=4 cam crank etc?
If I take advantage of all 38 assuming no interference that is crank degrees. There's a ton of numbers involving teeth = degrees vs cam and crank. One tooth is 14 crank degrees right? Cause I see 3.5 degrees being referenced as half tooth consistently. X2 for whole tooth and x2 for cam to crank ..
38 total advanced, plus the -1.2 available leaves a range of 39.2. Is that correct?
So 38 minus 14 for one tooth retarded is 24 leaving 24 minus 39.2 is leaving us with -15.2 crank degrees .
Does this add up?
That kind of mivec retard, would it amount to a higher efficiency at high back pressure?
Skidonner90
18
Oct 20, 2015 06:08 PM
Grimgrak
Apr 28, 2015 01:49 PM
EVOkeeper
Jun 22, 2014 08:43 PM
Javier F.
Dec 28, 2011 11:43 AM
Oracle1
Apr 6, 2008 08:39 PM
