Another evo 8 only getting 12 psi
Old Nov 8, 2013 | 10:47 AM
Ryan4dc's Avatar
Will try after work today, and test drive on the way to my second job.
Old Nov 9, 2013 | 10:28 PM
sparky's Avatar
So, what happened?
Old Nov 9, 2013 | 11:17 PM
DsmGuy86's Avatar
Originally Posted by sparky
See my post #12 above, and follow those steps so as to determine actual WG spring pressure. From there we will try increasing spring tension. The most likely scenario is that your turbo's WG flapper is fully open by 12# due to insufficient spring pressure, me thinks
I agree with this I think it could be your WGA. If you do what sparky says and still only get 12lbs it's more the likely the wast gate
Old Nov 10, 2013 | 02:12 AM
Ryan4dc's Avatar
It's been raining, and next available time is after work tomorrow to bypass the pills and solenoid. Sorry.
Old Nov 10, 2013 | 04:37 PM
Ryan4dc's Avatar
How it sits as of now. After work will be the test drive.
Old Nov 10, 2013 | 05:14 PM
Ryan4dc's Avatar
Same, 12 psi. With a vac hose jumped from j pipe to waste gate actuator.
Old Nov 10, 2013 | 06:12 PM
Ryan4dc's Avatar
Found this. Will try tomorrow. Thanks.
https://www.evolutionm.net/forums/ev...nt-anyone.html
Old Nov 10, 2013 | 06:29 PM
BrokenTurbo's Avatar
another thing to check is your manifold and gaskets, i had a crack in my previous manifold and i had low boost until i found it 3 week later. after trying and replacing alot aof parts.
Old Nov 10, 2013 | 08:29 PM
Ryan4dc's Avatar
So is 1/4 inch too short a good preset? If I preload the spring that much, how does the bcs control boost if the wastegate spring is set at or around the desired boost? Ill effects of having too much preload?
Old Nov 11, 2013 | 12:38 PM
sparky's Avatar
Originally Posted by Ryan4dc
So is 1/4 inch too short a good preset?......
Is a 1/4" of what too short? Are you refering to cutting a 1/4" off the threaded end of the actuator rod? Lop 3/8" off. Reinstall the turnbuckle afterwards leaving the backup nut off. Screw the turnbuckle down until the tip of the rod bottoms out inside the turnbuckle. Get rid of your fear.
Old Nov 11, 2013 | 12:53 PM
Ryan4dc's Avatar
Removed the heatshields, wastegate arm was on there kind of tight. Used a screwdriver to remove the arm. From the YouTube videos I saw, this is where it should be........
Didn't adjust anything.
Old Nov 11, 2013 | 12:59 PM
Ryan4dc's Avatar
Now I'm stuck trying to get the arms back on. Lol.
Old Nov 11, 2013 | 01:05 PM
sparky's Avatar
So, if you saw 12# running straight from the comp nipple to the WGA 12# iis your spring pressure. Your WG flapper is full open @ 12#. If it is full open at twelve PSI we can infer that it cracked up off the seat and started lifting at a much lower level of manifold boost pressure. The flapper is probably half way through its arc by7-8#. The spring tension needs to be increased considerably.
Old Nov 11, 2013 | 01:14 PM
Ryan4dc's Avatar
In the pic, with the wastegate flapper in the full closed position, the very end of the arm is flush with the round tab the arm attaches to. So I adjust it even shorter at this point?
Old Nov 11, 2013 | 01:22 PM
Ryan4dc's Avatar
Better pic with flash on. Lol. Hard with all the wind and tight space under the hood.
