evo 4-9, same clutch specs and oem maintenance parts
Old Nov 8, 2013 | 12:03 AM
jmb_silvester's Avatar
Hi everyone, I'm not sure if this has been ask before, I just want to know if evo 4- 9 have the same clutch specs and OEM maintenanance parts like:
Clutch disc
Pressure plate
Timing belt
Balance shaft belt
Tensioner bearing
Idler pulley
Shaft tensioner bearing
Old Nov 8, 2013 | 01:38 AM
wreckleford's Avatar
Timing stuff is the same, but the 7 to 9 use a bigger clutch setup. You can put the flywheel onto a 4-6 though and then use the 7 to 9 clutch and pressure plate.
Old Nov 8, 2013 | 05:13 AM
BlackEvo_5's Avatar
yup, he is correct
Old Nov 8, 2013 | 06:04 AM
Kracka's Avatar
Pretty sure the IX has a longer timing belt than the previous models due to MIVEC.
Old Nov 8, 2013 | 06:11 AM
Ecr33's Avatar
WRONG i know the 8 and 9 have the same timing belt
Old Nov 9, 2013 | 03:38 AM
BlackEvo_5's Avatar
yup, same length etc but I think the 9's belt is kevlar backed.
Old Nov 9, 2013 | 06:49 PM
ACTman's Avatar
Examining the different clutches, the Evo 7 clutch has a different pressure plate leverage ratio than the Evo 8-10 and requires less travel to operate.
Old Nov 10, 2013 | 05:20 AM
94AWDcoupe's Avatar
the evo 7 and 8 is same car. I doubt the clutch cover had any changes. but if they are different they certainly interchange. the 4,5,6 clutches however are 10mm smaller in diameter. so when using 8/9 clutches in early cars the bigger flywheels must be used as well.
Old Nov 10, 2013 | 04:59 PM
ACTman's Avatar
The 7 and 8-9 stock clutches test differently and have different part numbers. That doesn't mean they don't interchange, but the results may be slightly different. I haven't compared the cars (pedal assembly, hydraulics, etc), just the clutches...
Old Nov 10, 2013 | 05:01 PM
thanks everyone, appreciate all the reply.
I ask those things cause i need to replace mine and someone here is selling stuff like that and he said its the same from 4-9, now that i know only timing belt and other bearings are the same, i should look for 4-6 clutch and pressure plate.
Other thing i need to confirm regarding timing belt, does it have 153 teeth?
to save posting i will ask also here, what spark plugs are recommended for Evo 4-6?
turboedv6
28
May 13, 2016 04:31 PM
orion4096
35
Jan 25, 2016 03:37 PM
bpdean
19
Dec 29, 2015 03:08 PM
xXANCHORMONXx
Oct 5, 2014 02:45 PM
LithiumX
Jan 14, 2010 10:08 PM
