checklist for 120k maintenance & clutch flywheel
I need to get a 120k service and clutch and flywheel replaced, I am getting a local mechanic to do all the work as long as I supply the parts.
I went over to the dealership to pick up parts for the 120k service and they were no help, they gave me all sorts of weird numbers and once I got home and typed the part numbers in at an oem vendor site I got cheaper prices but the parts are not even correct.
so here is what I think I need:
For 120k
MR994968 Timing belt
MN137247 Timing belt tensioner pulley
MR984375 Timing belt auto-tensioner
MR984778 Balance shaft belt
MD352473 Balance shaft belt tensioner pulley
MD979395 Water pump kit (includes gasket and O-ring)
should I go ahead and replace serpentine ?
anybody got the part number for cam seals ? should I replace them as well?
what else spark plugs airfilter and anything else ?
Clutch Flywheel
I got the fidanza flywheel and act 6 puck kit( bearing pressure plate and tool) do I need anything else? new fork or something?
One more thing, I think the flywheel bolts that fidanza sent are the wrong ones will the oem ones fit and if so anyone know the part number ?
if not where do I find Grade 12.8M12X1.25 fine thread 20 mm bolts that I can feel comfortable rotating at 6k rpm under load? (i dont know what kind of turn around time I am looking at with fidanza)
anything else you guys can think of that should be done? I havent really done anything major except replace brakes and change tranny fluid in the last 75k so let me know if I should look out for anything else.
thanks
For 120k
Clutch Flywheel
thanks
anyone know the part number for the oil pressure sending unit that goes bad all the time ? sorry the dealer is terrible I really don't want to be caught off guard by them again.
FS[Northeast]: Evo 8 Timing Belt Kit and Exhaust Parts
Walter1986
Jul 27, 2016 07:51 PM
alexc
Jun 16, 2015 11:20 AM
EvoNoob00
May 7, 2013 09:59 AM
os2
For Sale - Cars For Sale
Dec 30, 2010 11:41 AM
MJ23FE
Jan 25, 2010 05:10 PM
