Fuel regulator set up verification
I just wanted to make sure I set up my new fuel regulator right. I had the vacuum line for it plugged and set the base pressure to 44 psi (stock is 43.5 if I remember right and my gauge only reads in 2 psi increments so I figured a little more pressure is better than trying to guess where 43.5 was and getting it too low). So with that being said with then vacuum line reconnected and engine idling and pulling vacuum the fp should be lower than the base 44psi correct. I just wanted to make sure because I'm always second guessing myself especially when it comes to important systems like the fuel. Thanks
turbocheese
16
Nov 19, 2015 09:16 AM
Crufty Dusty
Aug 14, 2003 02:45 AM
