Car will only hit 26 psi on 5th gear
Old Dec 10, 2013 | 10:56 PM
JDM EVO 6's Avatar
all other gears 21-23 psi
what wga can I buy for a stock evo 8 turbo?
Or what home made solution?
Old Dec 11, 2013 | 02:16 AM
awdordie's Avatar
I would highly suggest not too be hitting boost in 5th gear unless your at the top of fourth. If your boosting it from a low rpm in 5th thats the fastest way to install a window in your block.
Dont know of any home remedies, and wouldnt suggest to "rig" an evo... dont be a ricer.
Also are you wanting to boost higher in fifth as the title implies since it says only boost 26 psi in fifth? Or are you wondering why its boosting higher than 22-23 like other gears?
Old Dec 11, 2013 | 04:41 AM
sparky's Avatar
I think that I know what the OP is trying to convey. If I am understanding what he is saying; the turbo only reaches his desired peak boost level (26#) in top gear. In gears 1-4 boost does not reach the desired peak level but instead peaks at 22-23#(or whatever). Is this the case?
Old Dec 11, 2013 | 05:24 AM
sparky's Avatar
OP: Most people here are gonna tell you to do a boost leak test, right off the bat. That's sound advise in these cases....so do the BLT ASAP.
Tell me how you are controlling boost on that turbo? What sort of BOV is fitted to the beast? Do you have any idea whether your stock VIII turbo(I assume) is configured with the 9.8cm housing, or if a 10.5 cm housing was installed?
Can you list ALL of the pertinent power mods on your ride please.....
Old Dec 11, 2013 | 05:35 AM
sparky's Avatar
BTW, is your drive a USDM Evo VIII, or an Evo VI?
Old Dec 11, 2013 | 03:59 PM
JDM EVO 6's Avatar
exactly car has been tuned and no leaks.
Ive had 5 Evos but this is the first with a stock 8 turbo. Most have had e9 at least which you just buy a 25 psi wga.
I only want to know of oem solution or after market wga for evo 8.
I want 26-27 psi tappering down to 21-23.
Old Dec 11, 2013 | 05:57 PM
heel2toe's Avatar
In every gear? What are you using to control boost? In order to gain control of your boost curve per gear realistically the only way is with the use of an electronic boost controller or utilizing a 3 port with the stock ecu.
Old Dec 11, 2013 | 09:29 PM
JDM EVO 6's Avatar
Originally Posted by heel2toe
[/B]
this car is using a hallman
thanks...so a stiffer wga wont help?
Old Dec 11, 2013 | 10:11 PM
Jerry321's Avatar
Was your Car tuned boost by gear? But usually tuners do that but boost lowers as it goes higher in the gears.
First thing perform a boost leak to explain what's going on with lower boost on the lower gears.
Old Dec 11, 2013 | 10:42 PM
sparky's Avatar
I can give you a "Homemade Solution" that should give you 23# in 1st, 24# in 2nd, 25# in 3rd, and a flat 26# in 4th and 5th if you are interested. At least it is worth a try before spending $250 on a FP HD actuator.
Of course your immortal soul and your 1st born will be my property. You do have a MBC and a hacksaw...don't you?
Old Dec 11, 2013 | 10:44 PM
shrtstuff89's Avatar
a 23psi WGA will guarantee that you have a minimum of 23psi, even with the hallman turned all the way down (which is how my setup is right now). It HAS to be tuned for any increase in boost over what was previously tuned. and honestly a stock evo 8 turbo probly cant produce higher than 26psi at the top of you powerband, which is why it would taper off . the stock 8 turbo only flows 505CFM.
Old Dec 11, 2013 | 10:51 PM
sparky's Avatar
Edited
Old Dec 12, 2013 | 05:28 AM
sparky's Avatar
Originally Posted by shrtstuff89
....a stock evo 8 turbo probly cant produce higher than 26psi at the top of you powerband, which is why it would taper off . the stock 8 turbo only flows 505CFM.
The OP never said that his turbo is exhibiting boost taper. He states that manifold boost pressure reaches an indicated 26 PSI in 5th gear. No one is talking about a boost taper issue....well, except you.
A lot of people have run 32 PSI+ out the top through a stock VIII 16G. It may not be advisable, but it has been done before. It is documented on this forum(i.e. Curt Brown, TurboTrix, et al).
His problem is that he can't hit full boost in the lower gears. This is a common problem especially in 1st and 2nd gears. But, by 3rd gear he should be seeing 23-24# at least. By 4th gear he should be seeing 25-26#, or substantially full boost. Of course the WGA has to be up to par with regard to spring rate and diaphragm and properly adjusted.
Old Dec 12, 2013 | 09:36 AM
JDM EVO 6's Avatar
its a 10.5 no boost leak
thanks sparky
Old Dec 13, 2013 | 06:04 PM
sparky's Avatar
I have a homemade solution for you. But, first I want to ascertain a few details about your specific setup. 1) How are you controlling boost? 2) What BOV/DV is on there? 3) What exhaust system components from the turbo on back?
