Car will only hit 26 psi on 5th gear
Old Dec 20, 2013 | 11:13 PM
JDM EVO 6's Avatar
mbc
e9 bov
dp o2 dump test pipe
Old Dec 21, 2013 | 03:31 AM
sparky's Avatar
Originally Posted by JDM EVO 6
.....I only want to know of oem solution or after market wga for evo 8....I want 26-27 psi tappering down to 21-23.
We should try modding the stock VIII actuator. It may be up to the task of 26-27#. At least it is worth a try and it won't cost you anything. If all else fails we go to an aftermarket heavy duty VIII actuator.
Did you already test to establish current wastegate spring pressure level? You have a MBC so just rotate the adjustment knob all the way out counterclockwise (-) to lowest possible boost setting. Do a WOT run in 4th and note peak boost level on your boost gauge.
Old Dec 21, 2013 | 04:21 AM
sparky's Avatar
Disconnect hose to actuator. Remove cotter pin that secures tip of actuator rod to flapper valve's pivot arm. Remove two bolts securing actuator bracket to turbo's compressor housing. Remove actuator assembly from turbo.
Secure the actuator by clamping the actuator rod in the jaws of a bench vise. Unscrew and set aside both the turnbuckle tip and its backup nut. Measure 1/4"(.250 inch) from threaded tip of actuator rod. Cut 1/4" off threaded tip of actuator rod(1/4" equates to about 4 threads) using a hacksaw or a Dremel cutoff wheel.
Reinstall the turnbuckle tip onto the actuator rod LEAVING THE BACKUP NUT OFF. Tighten the turnbuckle down as far as it will go along the threads bottoming the rod out inside the turnbuckle.
Reinstall the modded WGA assembly onto your turbo. Go for a WOT run in 4th gear. Check boost.
Old Dec 21, 2013 | 08:50 AM
sparky's Avatar
Yikes! I forgot to mention that after you install the modded actuator you must back your MBC adjustment knob all the way out counterclockwise to its lowest boost setting(-), before road testing at WOT.
The boost reading that you obtain from that test run is your new(preloaded) spring pressure level. From that base point you can increase boost via MBC knob.
Old Dec 21, 2013 | 01:43 PM
JDM EVO 6's Avatar
thanks 27 psi on 4th gear zero knock
tappers down to 23-24
siiiiick
thanks for the help amigo
Old Dec 21, 2013 | 06:14 PM
sparky's Avatar
Anytime! I am glad the issue is resolved, my friend.
ohmohm
31
Dec 12, 2015 12:00 PM
harp12
Mar 31, 2014 08:32 AM
2StepsAhead
11
May 9, 2010 08:37 AM
dookgvr4
Feb 15, 2010 04:39 AM
This_Guy777
Sep 25, 2008 03:32 AM
