Metal Shavings :(
Old Dec 18, 2013 | 04:35 PM
boostVIII's Avatar
Thumbs down Metal Shavings :(
blackstone said it was good and i was worried about air bubbles haha
Old Dec 18, 2013 | 04:48 PM
okevolutionVIII's Avatar
Pull the oil pan and take the rod caps off for a start.
Old Dec 18, 2013 | 05:45 PM
Frew's Avatar
I would pull the valve cover and look for anything out of place, excessive wear on the cam lobes, etc.
Old Dec 18, 2013 | 05:58 PM
boostVIII's Avatar
thanks for the replies guys! Im going to check all of the following when my friend lets me use his shop, if it is the valve train what exactly would i need to rebuild it for a larger power band? I know springs and retainers, but any recommendations?
Old Dec 18, 2013 | 06:22 PM
meckert's Avatar
If you have metal shavings its not from the Valve train---its bearings so bottom end.
Old Dec 18, 2013 | 06:25 PM
LetsGetThisDone's Avatar
Not entirely true. It could have eaten up cam or cam journal, or both.
Old Dec 18, 2013 | 06:37 PM
wc351's Avatar
I would start with the bottom end like others have said. Sounds like some sort of bearing failure.
Old Dec 18, 2013 | 06:52 PM
gpfury86's Avatar
I would definitely track down your issue first then worry about mods, metal shavings is no bueno. You can also drain your oil through some rags or coffee filters to get an idea of the amount of metal that's floating around in there.
Old Dec 18, 2013 | 09:41 PM
boostVIII's Avatar
Yeah when i drained it yesterday I circled a magnet around the oil and it didn't pick up that much but there were pieces that the magnet couldn't pick up.. I'm guessing it was aluminum shavings? maybe from pistons?
Old Dec 18, 2013 | 09:55 PM
Mercenary3's Avatar
I'd be sending in an oil sample to Blackstone or similar ASAP. They should be able to tell what type of metal it is, and consequently, what is going south. Either way, as others have said, if your seeing a lot of metal in the oil, that is no good. Just because the flakes are small doesn't mean it isn't serous. As you are collecting the oil sample, you cam filter the remaining oil and get a good idea how much metal there is. I'd avoid driving the car until you know what the deal is as well...not sure if that is possible or not.
Old Dec 19, 2013 | 12:32 PM
boostVIII's Avatar
yeah the car is not being driven at the moment. I did take a look at the valve train and everything seemed to be in tact. Ill post pictures of what i was looking at.
Old Dec 19, 2013 | 12:38 PM
boostVIII's Avatar
Old Dec 19, 2013 | 03:10 PM
BogusSVO's Avatar
Check your crank end play. More so if you have a heavy clutch.
If you do not have rod knot at this time.
The babbit face of the bearing is non magnetic.
SmurfZilla
Aug 16, 2015 03:50 PM
goforwand
Dec 29, 2013 07:47 PM
drifthobo
Dec 21, 2013 08:59 AM
