Evo 9 No Start After Cam Install - Good compression - Help me out
Old Dec 22, 2013 | 06:09 PM
Dann's Avatar
Check to make sure intake and exhaust cams were switched around. I got mine labeled wrong and could not figure it out for the life of me...
Old Dec 22, 2013 | 06:20 PM
reelbite's Avatar
I have a ix and the cams are not interchangeable from what I can tell from my old set.
Old Dec 22, 2013 | 06:44 PM
MRfabolous's Avatar
Did you check your ground for the exhaust cam pos sensor
Old Dec 22, 2013 | 07:03 PM
reelbite's Avatar
I removed it and reinstalled the ground.
When I was rotating the cams prior to running I heard a click in the lower cover and then It was gone, I lost a zip tie earlier In the day and I am thinking that $ .03 Plastic zip tie just cost me $100 and a headache.
Old Dec 22, 2013 | 09:49 PM
slowsrt4:('s Avatar
I had the same problem but on my VIII, I flipped the cam position sensor 180 degrees and still nothing. But then I flipped it a little differently and it worked. I referenced this site when trying to figure out how to align the cam angle sensor
http://www.evomoto.com/tech_info.php?tech_id=18
Old Dec 23, 2013 | 04:52 AM
reelbite's Avatar
Originally Posted by slowsrt4:(
I had the same problem but on my VIII, I flipped the cam position sensor 180 degrees and still nothing. But then I flipped it a little differently and it worked. I referenced this site when trying to figure out how to align the cam angle sensor http://www.evomoto.com/tech_info.php?tech_id=18
will the camshaft sensor cut fuel and spark? I also thought the camshaft sensor would throw a code? I'll triple check the sensor before I tear into the crankshaft sensor.
Old Dec 24, 2013 | 12:08 PM
reelbite's Avatar
Do to myself being sloppy during install a cut plastic tie from the camshaft pulley fell between the lower timing cover and worked its way into the timing belt and broke off the crankshaft sensor. I removed and replaced the crankshaft sensor and she fires up and runs as it should. Side note first impression of my Kellford 264's have a stock like idle and untuned i can feel the added torque. Im looking forward to getting a tune.
xRoguex
Dec 6, 2021 07:58 AM
xiMR
Nov 7, 2016 09:50 AM
TheGeniusMoose
May 3, 2015 08:31 PM
Ozrally-king
Lancer Troubleshooting
Sep 16, 2014 11:24 PM
anthonypazsd
Jan 31, 2010 03:01 AM
