Evo 9 No Start After Cam Install - Good compression - Help me out
Old Dec 22, 2013 | 06:29 AM
reelbite's Avatar
I have installed cams on dsms but this is my first evo swap. I aligned my crankshaft pulley and cam gears , used zip ties, when I got finished all marks line up properly and my compression is 180, 160, 180, 180. I was searching and I found that Evo 9 compression should be around 145, Is there something that would cause high compression and no start? I switched around the orientation on my exhaust cam sensor with no change. Any help is appreciated... im at a loss and do not want to re-time if there could be another problem.
Spark test - FAILED
FLIPPED Cam Sensor 180 - FAILED
FLIPPED Intake Sensor 180 - FAILED
Fuel Pump Activation (cyl / plugs are dry)- PASSED / FAIL
Compression Test - PASSED
Fuse Panel - PASSED
Wiring Harness - PASSED
CONCLUSION:
Do to myself being sloppy during install a cut plastic tie from the camshaft pulley fell between the lower timing cover and worked its way into the timing belt and broke off the crankshaft sensor. I removed and replaced the crankshaft sensor and she fires up and runs as it should. Side note first impression of my Kellford 264's have a stock like idle and untuned i can feel the added torque. Im looking forward to getting a tune.
Old Dec 22, 2013 | 06:54 AM
GreenAWD's Avatar
Check fuses. There is one under the dash that likes to blow.
Old Dec 22, 2013 | 08:10 AM
kailoma679's Avatar
check all your connections.
Old Dec 22, 2013 | 08:24 AM
4g63evoeight's Avatar
sounds like you may have one of the cam positioning sensor intake or exhaust wheel things ( cant think of the actually name lol) installed backwards.. that would cause it to not start
once you remove the 3 10mm bolts holding the cover plate on for each cam, theres the 12mm or 14mm bolt holding it on. make thats installed correctly and not 180* out of phase
Old Dec 22, 2013 | 09:17 AM
reelbite's Avatar
My plugs are bone dry and i pulled one of the spark plug wires and grounded the side of the plug and i am not seeing any spark. What sensors will pull spark and fuel?
Old Dec 22, 2013 | 09:51 AM
lostsoulsevo's Avatar
Crankshaft position sensor plugged in?
Old Dec 22, 2013 | 10:33 AM
reelbite's Avatar
Im going to pull the lower timing cover and inspect it.
Old Dec 22, 2013 | 12:59 PM
GreenAWD's Avatar
Check your fuses!!!!
Old Dec 22, 2013 | 01:21 PM
sr20det91's Avatar
The first thing I would check is the CAM angel sensor trigger. Easily reversed 180 degrees, and is the cause of many "no starts" after cam installs.
Old Dec 22, 2013 | 01:27 PM
cmspaz's Avatar
There's a 10A fuse under the dash for ignition. Check that BEFORE you take anything else apart. Don't be dumb.
Old Dec 22, 2013 | 04:02 PM
reelbite's Avatar
I've checked all fuses, I am definitely not getting spark, and my plugs are dry. I'm going to purchase a crank shaft sensor An give that a try, hopefully that fixes the problem. I have flipped the cam sensor with no change. I notice the rpm gauge dosnt move when starting, is that normal?
Old Dec 22, 2013 | 04:27 PM
exactly what i tried telling him
Old Dec 22, 2013 | 04:51 PM
reelbite's Avatar
I have tried flipping the cam sensor 180* unfortunately that's not the problem.
Old Dec 22, 2013 | 05:25 PM
GreenAWD's Avatar
Are you getting any codes?
Old Dec 22, 2013 | 06:00 PM
reelbite's Avatar
no codes, it's gotta be the crank shaft sensor... Maybe a zip tie got down there and broke it.
