Practical Mods
Old Mar 1, 2004 | 07:54 PM
GOT2EVOS's Avatar
Practical Mods
i want to get some practical mods, money doesnt really matter, i just want something to drive that isnt going to break down all the time and put unnessesary wear on my engine, i also what a very well made high end product right now im looking to get the HKS 30th anni exhaust and HKS DP, HKS RS intake, HKS IC Piping, and ill be getting a custom dynotune/reflash soon. Yes, I am an HKS freak. Anyone have any suggestions for other practical mods. I would like to see my HP at around 330 to the flywheel, something similar to the FQ330, and i dont really wanna raise boost. Up to those who can gimme some sugg.
Old Mar 1, 2004 | 08:07 PM
1QWKEVO's Avatar
if u plan on drag racing, u might as well add an HKS clutch to the list becasue the car's stock clutch isn't going to hold launches well
Old Mar 1, 2004 | 08:10 PM
RADmitsu's Avatar
I would still recommend at least a manual boost controller to help hold ur boost... A dyno flash after those monds, and a intercooler , plus a fuel pump...
330 easy maybe 350 with a good tuner...
Old Mar 1, 2004 | 08:26 PM
SinCityEvo's Avatar
Reconsider the boost control. HKS makes a nice EBC. It will compliment your other mods well. Also agree on the fuel pump. high flow cat maybe? You don't really need the IC piping.
Old Mar 1, 2004 | 08:30 PM
mndeerslayer's Avatar
With a dynoflash and your existing mods, you should easily obtain 330 crank HP. This would only be a 60 hp increase from stock. The only problem is how to measure it.
Old Mar 2, 2004 | 05:12 AM
Zeus's Avatar
Buschur flashed Econo package... go check it out at their site. However, if money is no object, a professionaly installed Buschur flashed stage 3 with a good clutch would be on the upper end of your wish list... and damn fast too (however, way above your goals and not HKS).
Old Mar 2, 2004 | 07:09 AM
GOT2EVOS's Avatar
i have nothing against burschur or any other of the us tuners but i love the jdm stuff, and the only thing im worried about with the MBC is i want my turbo to last
Old Mar 2, 2004 | 11:26 AM
RADmitsu's Avatar
WHAT?
It's not about turning up boost... Holding boost is totally different... Remember boost is addictive, worst than crack in some situations... Also at some point a stronger clutch would be wise...
Old Mar 2, 2004 | 05:56 PM
dpardo's Avatar
I recommend a good-quality exhaust system, prefereably the quieter/more tasteful variety, and a Vishnu Xflash.
I have this setup and it's awesome!
It will run you less than $2000 and you should be around your HP goal.
A MBC is an inexpensive (relatively) way to go but it's also an easy way to blow your engine if you're not careful!
Old Mar 2, 2004 | 06:00 PM
GOT2EVOS's Avatar
clutch is a little down the road but it will come, ive come up with then first mod order and it is as follows: HKS RS intake, HKS DP, Espelir Catback, and i am getting a custom dynotune/dynoflash from Al on the 20th
Old Mar 3, 2004 | 12:39 PM
Zeus's Avatar
just got an email notification that David Buschur just replied to this post... was it deleted? If so, somebody give me the cliff notes?
Old Mar 3, 2004 | 02:22 PM
eclipsegs2k1's Avatar
GOT2EVOS, I am sort of in the same boat as you. I really like all the HKS products and I am sort of weary of holding the 19 psi all the way to 7k rpm's. Anyways, I have the Carbon-Ti catback and the Type 1 Turbo Timer and they are both wonderful products and I would reccomend both of them to you. The exhaust is a perfect fit and top notch quality, plus it has a great aggressive sound that is not too loud in any way. I kind of want to go with either HKS or Ralliart parts in the future, and I am thinking that I will go with Vishnu for the reflash but I will just have to see.
Also, this week I ordered HKS grounding wires and a ralliart filter element so if you are interested, I can give you an update once those parts are installed. Good luck.
rmondoh
Evo X Dyno Results
35
Jan 12, 2014 04:08 PM
rmondoh
North Texas Evo Club (NTEC)
29
Nov 2, 2010 06:39 PM
Magnus82
59
Aug 15, 2010 05:14 PM
mk4killer
For Sale - Cars For Sale
11
Aug 20, 2008 10:10 AM
EVOboostVIII
Jun 9, 2005 11:39 AM
