Question for you Speed Density guys
Old Jan 16, 2014 | 02:54 AM
  #46
211Ratsbud's Avatar
Originally Posted by mrfred
ok. I was just trying to point out that it looks to be the same sensor with slightly different packaging.
understood just posting that so someone doesn't cram it in three like an ofh fitting !
http://www.nzefi.com/product/inlet-air-temperature-sensor/
Says same curve as popular gm Delphi units..
Old Jan 16, 2014 | 12:04 PM
  #47
Talonboost's Avatar
This link, I don't see where it gives any part number or even who the manufacturer is. I don't see any association to vipec, but I do to Linkecu. On the Linkecu web page there is more info but it is just as vague about the mfr and part # info. The Linkecu page does seem to show a choice of threads - BSP taper, or 14mm. It also shows some nice looking bungs for the 0 280 130 085 and says that the 0 280 130 085 is the one they recommend for turbo engines.
http://www.linkecu.com/products/Inst...airtempsensors
Old Jan 16, 2014 | 12:14 PM
  #48
211Ratsbud's Avatar
Yes info is certainly lacking although I'm sure it can be found else where with proper Google fu .. I'm personally using the echlin gm replacement sensor for Delphi .
Old Jan 16, 2014 | 01:28 PM
  #49
Nimpoc's Avatar
Bump for experience with the AIT downstream of a WMi nozzle. I placed my GM AIT in the UICP and the WMi nozzle in the LUICP just in front of the air box. Seemed logical to account for the charge cooling.
Old Jan 16, 2014 | 02:41 PM
  #50
Talonboost's Avatar
What is the LUICP? Do you mean the LICP? Air on its way to the intercooler?
If so, I would say an upside is you should get stellar vaporization of the water/meth, because the air is hot there, and it has a long path from there to the cylinders, so, more time to evaporate. This should get the water/meth more evenly distributed to the cylinders, which of itself should be worth a lot. And you would be less likely to have a big ol' dumb droplet of water landing on your IAT probe, because there probably won't be any big ol' dumb droplets by the time it's gone that far.
A downside would be, you are getting probably less effect from your intercooler than otherwise. The intercooler can reject more heat to atmosphere if there is more temp difference between the air inside it and the atmosphere. You are cooling off the air quite a bit before it even gets into the intercooler, thereby losing some heat rejection. Your air temps in the intake manifold should be lower if you let the air go into the intercooler hot, then shoot the water/meth in after the intercooler for further cooling.
Another possible downside could be mist dropping out of the air and puddling in the intercooler tanks. This could be nasty if a puddle all of a sudden takes off into the air again, then you have a slug of water going to the engine which you wouldn't want. Don't know how much this is really going to happen, but Richard L of Aquamist has talked about this.
A question this brings up is, do you really want to vaporize as much of the water/meth as possible before it gets into the cylinders? Or is it better to have only some of it vaporized and some that is merely atomized (or in very small droplets)? That I don't know, but I think ideally you want some of both.
Old Jan 17, 2014 | 09:33 AM
  #51
Chris@nolimitmotors's Avatar
Old Jan 17, 2014 | 11:31 AM
  #52
Nimpoc's Avatar
Sorry, lemme clarify: I'm running the stock upper IC pipes of which there are two, so I was referring to the lower-upper IC pipe (post IC).
On thread - I'm curious if the IAT change when spraying will be a good thing to account for as the car is going to be running dual maps, one maximum lameness CA91, and the other 50/50 WMi. That's why I put the IAT downrange of the nozzle.
If anyone has experience with this it'd be great to have some advice on the effect to the tune. I don't generally drive in sub-freezing weather, but 40-100F+ is normal over the year.
Old Jan 17, 2014 | 12:10 PM
  #53
Talonboost's Avatar
Ok, cool, so it sounds like you are doing what I am sort of planning on doing - nozzles near the outlet of the intercooler, IAT near the throttle body. Trying to give a fairly long path for the water/meth to meld with the intake air (per Richard L). Speed/density - that way I don't need to put my GM MAF (which I have used for years and really like ) or any MAF there in the blow-through position where it would have water/meth blowing through it. And, vent to atmosphere Blow-off valve - where? In the lower intercooler pipe I guess? Dual maps - with and without water/meth. Yup yup. Ooo I've got 92 octane here though
Yeah I agree, bump for anybody doing it this way to comment on the effect to the tune.
Evo_9xxx
Nov 7, 2020 04:58 AM
youra6
Jan 7, 2017 02:41 PM
dw cuz
26
Oct 13, 2016 05:08 AM
Tomvas1992
Jun 22, 2016 09:44 AM
guyver858
Sep 4, 2013 08:42 AM
