Evo 9 turbo wheel question
Old Jan 20, 2014 | 03:17 PM
Hołek's Avatar
Colleagues can any of you know the diameter of the rotor of the turbine exhaust evo 9? Was there any difference in their diameter when the turbo came out with the turbine housing F5 or A3N? When measuring a hole in the turbine housing comes to me 1mm difference.
EVO 9 MR I had a turbine housing?
Old Jan 20, 2014 | 06:16 PM
egis's Avatar
My evo 9 turbo is from '06 evo 9.if I remember correctly it's 49mm.i don't know anything about F5 or A3N,sorry.
Old Jan 21, 2014 | 07:42 AM
Hołek's Avatar
Thank you.
You have a GSR or MR?
And you can read what you sign the turbo housing?
Old Jan 21, 2014 | 08:19 AM
joseph143's Avatar
https://www.evolutionm.net/forums/sh...890&styleid=27
Googled this... Hope it helps
Old Jan 21, 2014 | 03:47 PM
Hołek's Avatar
Thank you. I read this already but there is nothing on the size of the rotor: (
Old Jan 21, 2014 | 03:54 PM
joseph143's Avatar
http://www.4gtuner.com/topic/12852-evo-turbo-specs/
you want the specs for the turbine wheel? or the compressor wheel?
Old Jan 21, 2014 | 03:56 PM
ak47po's Avatar
Old Jan 21, 2014 | 03:58 PM
joseph143's Avatar
http://highboostforum.com/forum/show...892-Turbo-size
should take care of it... i hope
Old Jan 21, 2014 | 04:22 PM
todd6027's Avatar
F5 or A3N was the material the housings were made from ,no difference in size
Old Jan 22, 2014 | 12:17 PM
Hołek's Avatar
If only differ in material, why is 1mm diffrence in the hole? And as ever wanted to
change the housing of A3N on f5 is did not fit?
Old Jan 22, 2014 | 12:27 PM
94AWDcoupe's Avatar
housing with bigger hole is modified. the turbine wheel is same size for all tdo5h turbos.
Old Jan 22, 2014 | 12:48 PM
Hołek's Avatar
So please tell me what turbo wheel is 1mm larger than oem and fit?
Old Jan 30, 2014 | 02:39 PM
Hołek's Avatar
I know the answer to your question. I bought a turbine wheel from the U.S. EVO9 and it is about 1mm larger than the euro EVO9. In the housing F5 wipes of wall, while a perfectly A3N
DSMolition
Mar 16, 2014 04:32 PM
jid2
15
Dec 28, 2012 07:44 AM
midegade
15
Mar 9, 2011 06:45 PM
LION evo
Mar 13, 2009 05:36 AM
Ree
19
Feb 13, 2004 09:05 PM
