Help, car will only go into 3,4,5,R
Old Jan 27, 2014 | 06:37 AM
89Saleen141's Avatar
Did some research and couldn't find a good answer. I just had a twindisk installed and for the first few days my car was running like a top. But then it was harder and harder to get into first. Then all of a sudden i couldn't get into first at all! Then later, seconds is gone. My shifter now seems very sloppy and i feel like I can get into 3rd and 4th from 4 different locations. I tried pumping the clutch to help get into gear and that didn't work. (Heard that helps with a twindisk). But I feel like something went wrong at the shifter base and maybe A clip fell off or something. Idk I need some advice as I will be taking the center console off and taking a look. Btw Sometimes i get into where 1st should be and it feels like 4th.
Old Jan 27, 2014 | 06:55 AM
meckert's Avatar
check shift bushings under the hood first, then check shift bushings in console. Last you could have lost a shifter fork.. but check the easy stuff before drawing conclusions
Old Jan 27, 2014 | 07:51 AM
Will do, thanks!
dan718
Jun 11, 2018 03:15 PM
throttledrop4
12
Jun 2, 2014 11:43 AM
weap0n
May 17, 2012 02:54 AM
tehSteve
Jul 5, 2011 08:51 PM
Paulito
May 31, 2009 09:23 PM
