View Poll Results: Which Oil Filter For The EVO?
Mobil M1 - 108
108
29.51%
Genuine Mitsubishi Oil Filter
233
63.66%
I Just Use the Cheapest One That Fits
25
6.83%
Voters: 366. You may not vote on this poll
Which Oil Filter?
Old Dec 19, 2004 | 11:19 PM
  #106
Joey B's Avatar
Veteran: Air Force
Originally Posted by 90GSX-03EVO
Nice!!! Thought that one was gone forever!
Reading this you just might see why the original site was taken down.
Thanks 90GSX-03EVO!!!
Joey
Old Jan 19, 2005 | 12:02 PM
  #107
ERGO EVO's Avatar
All,
Just spoke with a Denso guy in their tech department. The new filter is indeed made by Denso, but they do not produce the MD356000. That filter is made by a company called Toyo Reeki (sp?). Anyone in the industry ever heard of this supplier? Denso got the biz during the consolidation effort on the part of Mitsubishi to get down to fewer filters which can serve a variety of model applications. Thought this might be useful information to pass along.
Old Jan 24, 2005 | 06:40 PM
  #108
loffiekadaffi's Avatar
I just used a NAPA Gold filter that crossed referenced from the factory number. I was told at my dealership I could do this because I don't have a MIts. dealer locally. I just made sure it had a check valve.
Old Feb 4, 2005 | 02:35 PM
  #109
mitsuorder's Avatar
Anyone have the psi relief valve rating of the old MD356000 filter? I ask this because I'm about to change my oil again and previoiusly used a K&N HP-1010 which has a rating of 13-17 psi. My concern is that K&N recommends the HP-1008 filter for our cars with a rating of 11-17 psi, only thing is that this same filter is recommended for the non turbo lancers as well. I do not have a great knowledge of oil filters so I am asking if it is ok to use the K&N HP-1010 with it's psi rating and if that psi rating is on par with the old styl MD356000 filters that I have heard are of a better quality.
edit: Ok upon further inspection of K&N's website the hp-1010 is also recommended fo the 2003 non turbo lancer, then I looked up on top of the page to see what was listed for the 05's, this is what it said 2005 MITSUBISHI LANCER 2.0L L4 F/I - Turbo
http://www.knfilterchargers.com/sear...x?Prod=HP-1010
Old Feb 4, 2005 | 08:49 PM
  #110
IOevo's Avatar
exactly. ive spoken with numerous managers at auto parts stores, and even a service tech at honda. they tell me the mobile-1 has the best filter system.
the filtration is better because the element inside has more, smaller holes ans the stock filters (most manufacturers) have large holes, to pass the oil thru quicker. the mobile units have smaller holes and have a thicker element as well to help with preasure bilud up. i have heared lots of great stuff on mobile filters. what i have heared about stock units, they just work
Originally Posted by RonV
I did alot of research and spent alot of time on the Phone with Champion Labs and Mobil. To make a long story short, M1-108 is the correct filter. People are thrown off by it's size difference.
The outer canister is only a small part of the equation. The Evo makes some insane oil pressure compared to most cars , including sports cars. The inner cartridge has to be able to withstand the pressure without deforming to filter correctly. You can call Chamion Labs ( MFG of MOBIL 1 filters ) if you need more proof. Take Care
Old Feb 21, 2005 | 02:20 PM
  #111
jfh's Avatar
jfh
Often times filters that have finer particulate mediums tend to bypass that medium more often than those that do not filter down to the same particulate size. So while the filter may be capable of removing anything larger than 10 microns, it can only do so when the oil passes through the filter medium. When the volume of oil to be filtered surpasses the mediums capability to flow that volume, the oil is routed through the bypass valve. When this happens your oil is not filtered at all. Under high demand driving situations, this happens far more often than you may want to believe. There is no Holy Grail in the filter world, everything is a compromise. I am satisfied that the Mitsubishi engineers have done their homework on the lubrication and filtering requirements for their products and I trust their recommendations. Who cares if the same filter is shared between platforms, that doesn't make it an inferior product. If you vigillantly follow scheduled maintenance intervals with products that meet or exceed the manufacturers specifications, your car will last a very long time.
Old Feb 23, 2005 | 01:02 PM
  #112
evoviiiyou's Avatar
Cheapest. The manufacturer has us brain washed into thinking if you don't use there part then all done. If you are changing your oil every 3-5k then oil filter has less importance.
Old Feb 23, 2005 | 02:00 PM
  #113
donutmonkey's Avatar
Or you could just use the stock filter. They're under five bucks.
Old Feb 23, 2005 | 05:27 PM
  #114
feriosi'evotwin's Avatar
stock mitsu is the only way to go
Old Feb 23, 2005 | 06:38 PM
  #115
mitsuorder's Avatar
Or you could read the thead and realize that the Evos in Japan are using the old part number MD356000 filter which is why most of us are concerned. It is a fact that MMNA is not doing so well financially, they started making the filters universal to save money. I for one don't put much faith in Mitsu USA, then again I don't put much faith into anything... Still on the quest for the MD356000 filter psi relief valve rating.
Old Feb 23, 2005 | 07:32 PM
  #116
Concerned about what, exactly? I have read this thread, and that thread. I have read enough opinion, heresay and misinformation to compile a short novel. Why - exactly is the new part number not a good filter? Please give us some facts.
I bought a dozen stock replacement fliters about half a dozen oil changes ago and have had zero issues. They are not the same part number that came with the car. So what?
Old Feb 23, 2005 | 08:22 PM
  #117
mitsuorder's Avatar
I am not saying for sure that the new one is bad, but if you would open your eyes and read some of the cross references for aftermarket filter for Mitsu cars you will notice they all have differing psi relief valve rating, then all of a sudden Mitsu makes one to cover vehicles ranging from economy car to high performance turbo car. I am not arguing with you, I am stating reason for my concern. Do what you want, I will invest my time in a little homework before swallowing what MMNA feeds me.
Old Feb 23, 2005 | 08:52 PM
  #118
All I'm saying is so what. I'll say it one more time. Just because a part number changes, or fits other vehicles, means nothing.
The Exedy Stage 2 clutch kit for my 1987 Starion also fits everything from a Mitsubishi Galant turbo, to a Mazda B2600 pickup. Does that make that part better or worse depending what vehicle it goes on? Please.
The Mobil1 filter that fits the Evo cross references to my two-cylinder 1000 cc Honda motorcycle, so that point is moot.
So yes, my eyes are open.
Old Feb 23, 2005 | 09:54 PM
  #119
mitsuorder's Avatar
Good to know. I came in here with a good attitude voicing a concern. Anyone here that could carry on a conversation as to WHY there are differing psi relief valve ratings for mitsu vehicles, I would be greatly appreciative.
Old Mar 30, 2005 | 12:06 PM
  #120
Nez136's Avatar
i love mobil 1
