decided finally.. 2.2(4g63) at jackson automachine shop
Old Feb 16, 2014 | 06:14 AM
6466evo's Avatar
it was quite hard to decide between 2.0, 2.0lr. 2.1 2.2...finally decided on 2.2 build based on 4g63 wiesco pistons for 2.2, 153mm R&R rods +625 bolts ,k1 94mm crank part number(032bc940) balance shaft delete kit...than it was hard to decide which shop to choose to build the block from...after speaking to few shops spoke to tony @ jackson automachine shop finally decided to send the block to tony... Car is daily driven and for weekend drags, with 6466 turbo with ported polished head kelford 272 cams 1mm over size valves,map rev 3 intake manifold 70mm throttle body
been assurred by tony that this will be a stout combination and can rev 9500rpm easily can handle high boost.. which im planing 45psi of 6466 on meth if everything goes well....what do u guys think of this combination...another thing i was concered about is K1 crankshaft on k1 website they have 2 cranks leight weight crank which is 30lbs and another one is 32lbs so whats the weight of this part number (032bc940) and whats the price difference
thanks
Old Feb 16, 2014 | 06:43 AM
Roadrunr's Avatar
Meth?
Old Feb 16, 2014 | 07:00 AM
e_kobz's Avatar
The difference is around $250.00 bucks if I remember correctly. I was looking at this crank not to long ago and I remember seeing the standard K1 crank at $1399.99 bucks and the light weight one at 1649.99 or somewhere in that ball park.
Did you get your rotating assembly from English Racing?! They're the only ones I know of who sell a 2.2L stroker kit with all the parts you mentioned.
Old Feb 16, 2014 | 05:34 PM
6466evo's Avatar
got the R&R rods and 625 bolts from english racing as they had it in stock and getting the rest of the parts from jam tony will be supply rest of the parts wiesco 2.2 pistons, bearing, k1 crank and front cover,
guys is there any difference in english racing 2.2 wiesco pistons,and wiesco standard 2.3 stroker pistons?
Old Feb 17, 2014 | 07:46 AM
dr_latino999's Avatar
Veteran: Army
I ran into an issue with R&R rods from English Racing, but getting the Wiseco pistons off the shelf from another vendor at a different time:
Old Feb 17, 2014 | 10:33 AM
Roadrunr's Avatar
The compression height will be different if your rod length is the same as a 2.3.
Old Feb 17, 2014 | 07:08 PM
6466evo's Avatar
will speak to tony...see what he says...will report back
Old Feb 24, 2014 | 12:58 PM
TonyJAM's Avatar
Common issue with parts from different manufacturers. A little time on the mill and they'll fit perfectly We've got a few projects in here right now consisting of the exact same setup, it's becoming quite popular.
Old Feb 24, 2014 | 01:17 PM
bbong's Avatar
You're going to be happy with JAM and Tony, so far everything he said my engine would be, it is! I can't wait to put more load on it, but winter's been really harsh for us this year so loading up engine is going to have to wait until Spring. Best of all, my engine stopped consuming oil!!!
Old Feb 24, 2014 | 01:57 PM
Tuxevo's Avatar
Good choice of components, bad choice on the shop. There's a lot of horror stories about JAM. The theme usually goes, "they were great on the phone, then they took forever, then my motor exploded, then they were impossible to get a hold of". Why didn't you just have English Racing build it?
Old Feb 25, 2014 | 06:22 AM
TonyJAM's Avatar
Unfortunately no shop is perfect but thankfully things have changed for the better since I've taken over and we have more satisfied customers than not. The reality is that poor reviews spread like wildfire while happy customers tend to be more reserved. I hope to continue to earn your trust and undo the damage that's been done. I can provide references for anyone considering our services.
Old Mar 13, 2014 | 11:21 AM
6466evo's Avatar
tony is the block ready?
Old Mar 15, 2014 | 06:50 PM
6466evo's Avatar
jam 2.2 block is ready...will be getting the block collected next week...tony said i will be very happy with the block,turn out really well,cant wait to have it installed..will post pics up as as i receive the block...
Old Mar 16, 2014 | 06:44 AM
bbong's Avatar
You're going to be happy with it , i had 2 blocks built before JAM and both of them were oil hungry , after giving JAM a chance my engine now consumes no oil !
Old Mar 20, 2014 | 01:07 PM
6466evo's Avatar
yes...hopefully shortblock is getting picked up tomorrow...will post pics up when i receive it
