4g64 2.2 destroker pistons
Old Feb 18, 2014 | 08:54 PM
j.p.'s Avatar
Hi all!
now that i've decided to build a 4g64-2.2-94mm stroke-156mm rod- destroker I have a few questions to ask:
1. are the pistons in a 4g63-94stroke-150rod stroker the same as in a 4g64-94stroke-156rod destroker and the only difference is the diameter?
2.Which manufacturers make a piston for the 4g64 94mm stroke 156mm rod length destroker?any asymetric options?which would you recommend?who could supply them?
3.What compression ratio would you recommend? it's a time attack car,runs on e85, garrett gtx3582r turbo,dogbox,motec
Old Feb 19, 2014 | 08:53 AM
JohnBradley's Avatar
If you are building a 4G64 based 2.2, use 159mm rods and the compression height is 28.7mm
Eusebio Ponce
17
Jan 7, 2021 03:23 PM
R/TErnie
80
Jan 7, 2021 02:46 PM
ChrisO86
15
Nov 25, 2016 12:49 AM
Ckeesee12
Feb 6, 2016 07:50 AM
jameswwt
55
Dec 17, 2015 01:06 AM
