Only seeing 14psi on 1st gear
Is this normal. I just installed by defi bf boost guage and I am only seeing 14 psi on first gear. I only get to see higher boost (19.5) on every gear after that? Anyone care to elaborate?
yeah i agree with ev8sive, boost controller upgrade will stabilize the psi and keep it from tapering off at higher rpms too.. i'm just concerned about the 14 psi drop, maybe you are referring to the tapering off
Originally posted by EvoJimbo
Make sure all the lines are properly connected and tight. Keep in mind that you will never hit your desired boost or max boost on 1st gear!
