Who makes O2 housing that won't crack?
Old Mar 5, 2014 | 03:33 PM
R717's Avatar
Megan O2 housing, no external leaking, but the thin wall between the 2 sides is cracked, near the flange. Will this effect performance?
I like the Invidia built and finish, but I haven't seen any positive review.
Old Mar 5, 2014 | 03:41 PM
R717's Avatar
Old Mar 5, 2014 | 03:51 PM
Ag4G63's Avatar
Well if it's not leaking it will be ok.....for now. It will however continue to weaken with heat and time. You could pop it off, clean it up, and have someone reTIG it to strengthen it.
Old Mar 5, 2014 | 04:10 PM
ThatOneKid's Avatar
Map makes a really good one. If you're looking for a piece of art go with toxicfab.
Old Mar 5, 2014 | 04:19 PM
R717's Avatar
Thanks, the toxic one is open dump, I'd rather keep it quite.
Old Mar 5, 2014 | 04:25 PM
Bhsj13's Avatar
I have the invidia one and it works great for me! it looks great also.
Old Mar 5, 2014 | 07:16 PM
batty200's Avatar
Invidia is a great one for recirculating O2 housings.
Old Mar 6, 2014 | 01:24 PM
TommiM's Avatar
The MAP is a rebranded Megan, or from the same manufacturing place as a Megan unit.
Ive had a Megan and now using a Titek. The quality is much better and is substantially heavier than the megan unit I had.
Old Mar 6, 2014 | 01:29 PM
Ralliart004's Avatar
Veteran: Air Force
Works has a cast outlet
Old Mar 6, 2014 | 05:59 PM
alleggerita's Avatar
How did you find the Titek for power in comparison to the Megan - any difference?
Titek is beautifully made, nicer than all but the Works. However, the little dyno info that is available on these usually favours Works, Megan or Invidia ... however, at least one reputable tuner does not seem to be keen on the Megan.
Old Mar 6, 2014 | 06:18 PM
06ebevo's Avatar
i have the MAP o2 eliminator downpipe and i love it
Old Mar 6, 2014 | 07:53 PM
TommiM's Avatar
I have upgraded too many parts from the last setup to really make any fair comparisons.
When I had the megan O2 I had an evo 8 turbo w/10.5, stock cams. I then swapped out to a stock 9 turbo with a titek O2, Tomei 270 cams, and different exhaust.
nor11384
16
Feb 26, 2016 09:00 PM
ineedboostman
Nov 13, 2015 07:30 AM
mkcolgan
Nov 10, 2014 09:34 AM
Nimpoc
20
Sep 10, 2014 11:08 AM
