HELP! Top End Ticking
Old Mar 14, 2014 | 12:07 PM
Ichigo0Soul's Avatar
Veteran: Army
I got off the phone with them a little bit ago, and they told me that there was a very large amount of metal debris in the oil filter. So I did in fact spin a rod bearing. And badly. They estimated that it would be around $7000 for a rebuild. Is it just me, or does that seem a little bit high? And if I were to somehow facilitate a rebuild on my own, what would I need/roughly how much would that cost?
Old Mar 14, 2014 | 08:03 PM
Faisalm's Avatar
$7000 lol? Did they specify what was damaged?
$7000.... You can buy a Buschur 2.3 without supplying cores with that money and you'll have about $2000 left over...
Old Mar 14, 2014 | 08:47 PM
3K's Avatar
3K
I think you have to factor in the cost for labor.
Old Mar 14, 2014 | 08:55 PM
Faisalm's Avatar
Ah yes I always forget labor... I don't know how the rates are in the US but I'm assuming it still shouldn't cost that much?
Old Mar 14, 2014 | 09:06 PM
3K's Avatar
3K
Originally posted by:FaisalmAh yes I always forget labor... I don't know how the rates are in the US but I'm assuming it still shouldn't cost that much?
I don't know what that shop charges for labor, but if it includes decent parts that's actually not a bad price.
Old Mar 15, 2014 | 08:02 AM
Veteran: Army
I really just want to get the motor back to where it was before it spun the bearing. It was just a stock bottom end. I don't want anything special since I don't plan to be going above 400hp.
Old Mar 26, 2014 | 05:43 AM
Nagua's Avatar
Originally Posted by max mirni
ticking noise problem is just related to the engine oil problem or it is time to change your engine oil. Ticking noise indicates some sort of loose or hole in engine valve train. Any sort of leakage over there will definitely cause such ticking sounds. The problem is in cam and lifters and you need to change all these. So, you should prefer a good car repair center to solve this issue.
spammer
ApexLate
12
Mar 7, 2016 08:05 AM
Ksay3
Dec 5, 2015 12:12 PM
evolord21
Dec 1, 2015 10:53 AM
Hainec82
Oct 14, 2014 05:29 AM
evohmoob
Aug 27, 2013 03:50 PM
