fuel system upgrade path...
Old Mar 4, 2004 | 10:27 PM
gt40's Avatar
Got the brackets and everything made for the new fuel system. Here is a layout of it:
Old Mar 15, 2004 | 07:51 PM
gt40's Avatar
Install pic. I welded a steel base on each side of the trunk with 3 threaded studs on each. There is an aluminum bracket and thread plate pump and battery box on top of the base.
Old Mar 15, 2004 | 07:55 PM
gt40's Avatar
Here is a pic of the bracket.
The aluminum bracket sits on top of the base with the studs sticking through so that you can bolt/unbolt it. From there the fuel cell and battery box are bolted on top and the lines are run.
Old Mar 15, 2004 | 08:03 PM
gt40's Avatar
Last shot showing the sx fuel pump, filter and thread plate box which is welded to the bracket to make it more rigid:
