Budget stroker motor
Old Mar 16, 2014 | 11:08 PM
Faisalm's Avatar
I've heard of more than 30k miles on 2.3s. If you maintenance your car when you're supposed to and all that stuff, it should last just as long as you would expect an OEM engine to last.
Old Mar 17, 2014 | 05:57 AM
evolve_VIII's Avatar
Originally Posted by av00va
Since I'm tearing down the block I might as well put I-beam rods in it and a decent set of pistons. By budget I mean overall savings versus power and reliability. I told the shop doing the work I wanted to source a 64 block/crank to bolt on to my 63 head but they quickly downplayed the idea. I'm not saying they are misinformed, I'm merely saying our point of view is clearly different. From what I understand, the casting is more or less identical and the cranks are both forged. One lacks oil squirters but that is of minor importance. This would also give me the capability to turn around and sell a functional evo 63 block for what.. 3-500? That would effectively pay for the 2.4 crank but is it worth it considering I'd be in the market for a new waterpump? I'd also have to pray the timing is done right
The main difference in the block is that the bore is larger and the deck height is 6mm taller. Also, there are no oil squirters. The oil squirter debate has been discussed in this forum plenty of times. The way I look at it, Mitsubishi did not add these for the fun of it. They spent time and money in testing and designing these into the block. If you are going to do any type of racing, these should be added to the 64 block. The main purpose is to lubricate the wrist pin and cool the bottom of the piston.
63 blocks are becoming scarce. A good running short block is worth roughly $1,000 depending on miles, compression, etc... A bare block around 7-800 and crank around 2-300 depending on buyers and whatnot.
What's the life expentancy of a motor that is properly driven? I know this is the most subjective question ever but an average would do. A 2.3/2.4L has the higher stroke but of course it'd be built with quality internals. On the other hand it would see 500-600 WHP and some gruesome track days. I never beat on my cars but I expect them to perform. From what I gather, 30K more or less would be a good approximation
As for life expectancy, that will all depend on the abuse, tune, power, parts, but with a properly build motor 30k shouldnt be an issue. My last evo went 75K on a 2.4 making 500 on pump until the oil pump failed. It did see a lot of abuse which is why I think that the pump failed.
TheMowerman
Apr 13, 2016 05:59 AM
Ckeesee12
Feb 6, 2016 07:50 AM
RealStreet
Evo 'For Sale' Engine Internals and Drivetrain
31
Jun 10, 2014 10:54 AM
PRS
Jan 25, 2014 09:58 AM
RealStreet
63
Oct 17, 2012 09:12 AM
