2.3 motor problem help please guys
Old Mar 15, 2014 | 05:38 AM
mr evo7's Avatar
So the tuner says he was about to do ethanol map
He just finished setting the gsc s2 cams and findanza gears. He set cams at -1/+1.
He says the car kept burning the number 4 cylinder plug.. when they tested compression number 4 shows no compression. .
What do you guys suspect
Old Mar 15, 2014 | 05:41 AM
michaelrc51's Avatar
I would guess maybe timing is wrong and/or they bent the valves.
Old Mar 15, 2014 | 07:01 AM
mr evo7's Avatar
This is only on the number 4 cylinder. . Rest are all fine
Old Mar 15, 2014 | 07:35 AM
16vTAWD's Avatar
A piece of burnt plug probably bent or broke a valve.
Old Mar 15, 2014 | 09:26 AM
mr evo7's Avatar
How does it happen on 1 cylinder after tuning
Old Mar 15, 2014 | 08:33 PM
Pirana's Avatar
burnt ring land
Old Mar 15, 2014 | 08:58 PM
rjfg's Avatar
Originally Posted by Pirana
burnt ring land
This isn't a Subaru
Old Mar 15, 2014 | 09:26 PM
Pirana's Avatar
Originally Posted by rjfg
This isn't a Subaru
so what you are saying is that evo pistons don't have ring lands?
Old Mar 15, 2014 | 11:54 PM
mr evo7's Avatar
I still fail to understand how does it happen on 1 cylinder
Old Mar 16, 2014 | 12:23 AM
EvoJoeIX's Avatar
Check the valve springs
Old Mar 17, 2014 | 06:37 AM
mr evo7's Avatar
Ok well tha head is off and seems 1 exhaust valve is burnt.. all other cylinders are fine.
Any idea what caused this?
Old Mar 17, 2014 | 10:06 AM
Pirana's Avatar
I had a bad valve seal that kept leaking into the cylinder causing higher exhaust temperatures and melted the ring "land" in piston #2 seizing the ring. I ran like that for months not knowing as the car ran great....figure that one out!!!
Old Mar 17, 2014 | 12:02 PM
mr evo7's Avatar
Well it seems the spark plug that broke mades scratches in cylinder wall
legacydestroyer
33
Oct 11, 2014 04:38 AM
EVIL_EV0
11
Sep 19, 2014 05:27 AM
EvolutionRR
May 22, 2013 10:32 PM
iLancerEvo
Dec 15, 2012 12:24 PM
