World's cheapest 2.4L Build
Old Jun 8, 2011 | 08:04 AM
rocketguy's Avatar
Recently I bought a wrecked 2003 evo for 4 grand, 52k miles. It looked like an easy core support, radiator, intercooler, bumper, bend a few things back in place.. etc kind of fix. After digging into the car a little further, I found out the block is cracked. Needless to say, being a salvage title car it is going to be worth less in the end. Putting a stock 2.4 in keeps my TOTAL COST for the entire vehicle to just under $6000.
2.4 build:
Running 2.4 from friends salvage yard $400
Adjustable cam gears from ebay........... $48
MD-182292 timing belt...........................$73.90
Water Pump spacer (MAP)......................$24.99
Gallant head gasket (MAP).....................$84.99
My total comes out to just over 630 bucks. For wanting to keep the car as stock as possible (for resale purposes) I think that .4L of extra displacement will make the car a little more fun to drive on the street.. and correct me if I'm wrong, but a stock 4g64 bottom end should be good for ~350whp???
Please correct me if any of this information is wrong! Thanks!
Old Jun 8, 2011 | 08:06 AM
ravnos04's Avatar
With what turbo? stock 8 (10.5 hotside)? Or 9 turbo?
Old Jun 8, 2011 | 08:13 AM
rocketguy's Avatar
stock 8 turbo, going for ultimate budget 2.4
Old Jun 8, 2011 | 08:14 AM
scheides's Avatar
EvoM Moderator
Nice, post pics once you get the project rolling!
Don't forget all the little stuff --fresh valvestem seals and maybe a valvejob to keep everything up top fresh, a set of cams and fresh valvesprings (MAP and GSC make some basic beehives that are perfect) if it's an 8, break-in fluids, fresh drivetrain fluids all around is a good idea, and since it was in a wreck, check the brakes out and at least bleed them with fresh fluid.
Old Jun 8, 2011 | 08:18 AM
rocketguy's Avatar
Here is a pic of the car
Old Jun 8, 2011 | 08:22 AM
rocketguy's Avatar
I actually thought about doing cams on it.. but I can always put cams in with the engine in the car later (even though it is much easier when its out). Drivetrain fluids are definitely going in. In spirit of the complete budget built, and the fact it is (was) a low mileage 2.0, i'm going to skip everything to do with the valvetrain, though.
Old Jun 8, 2011 | 08:23 AM
rocketguy's Avatar
Here is the URL to my other thread, it has a couple more pictures of the car.
https://www.evolutionm.net/forums/en...ater-leak.html
Old Jun 8, 2011 | 08:46 AM
ravnos04's Avatar
with a 8, 10.5 turbo you can prob push close to 400whp with good e85 tune and supporting mods, but with stock everything prob around 350
Old Jun 8, 2011 | 09:35 AM
rocketguy's Avatar
350whp is really all I am shooting for since I don't want to strain the stock bottom end.. I will most likely have the ECU flashed once I make sure there isn't anything else wrong with the whole car. Thanks for the input!!
Old Jun 8, 2011 | 10:35 AM
RockmanX's Avatar
so basically a stock 2.4 not a built 2.4. mean One would wonder since the motor is out why would you not just go ahead and drop a set up better pistion rods bearings etc in there but i guess its all about getting it done and cheap as possible. Would be a thousand times easier to build it now and make the shorty hella stronger
Old Jun 8, 2011 | 10:40 AM
rocketguy's Avatar
RocketmanX - I agree in that it would be way easier to just build it now.. but the cheapest pistons and rods are around 930.. then you have bearings and rings and machining.... so basically we are talking an extra 1100-1500 bucks.
I don't think anyone has actually built a stock 2.4 evo on here, so I will either be the example of how to build a grenade for $600 bucks, or the example of how to replace your blown up motor for around 600 bucks
Old Jun 8, 2011 | 10:42 AM
project_skyline's Avatar
Not so sure about doing that on a NA 2.4 block. Sounds like a good way to shoot rods out the block.
Old Jun 8, 2011 | 10:45 AM
Aby@MIL.SPEC's Avatar
i forget what the 2.4 rods look like exactly, but they are a lot weaker than a evo8/9 rod.
Old Jun 8, 2011 | 11:01 AM
rocketguy's Avatar
I think its pretty impressive that all you see in engine shops "2.4l shortblock stage whatever" motors that they all essentially use the stock, unaltered 2.4 crank. Thanks for everyones input so far!
Old Jun 8, 2011 | 12:37 PM
3gEclipseTurbo's Avatar
The stock 4g64 is good for 340~wtq in fwd app before you start seeing problems. Ive tune more stock 4g64 motors than probably anyone on here, sense I mainly tune stock motor turbo 3g's and 8g galants. Just keep the tq below 330~ and 400whp is possible reving out to 7k
