bov
Old Mar 16, 2014 | 02:21 PM
febs1011's Avatar
bov
I admit I don't really know very much about bov's. I have recently bought this MR not sure if its stock tuned or not being that it has injen IC and piping but everything else is stock. I am wondering if my bov is leaking by. my car only holds about 14psi(1.0kg/cm2) it will build to 17psi(1.2kg/cm2), but immediately drops back to 14. I disconnected the side that is inline with the filter and MAF, at idle there is no leak but with a rev I can feel it with my hand.
Is this normal?
Am I checking the correct side?
I want to replace with recirc bov, but does it need replaced?
Old Mar 16, 2014 | 05:15 PM
adriano_917's Avatar
You are spiking 17psi and holding 14psi ? Also you want to replace it with recirculating bpv, so you are vta as of now ? You feel air when revving or revving then let go and you feel air.
Old Mar 16, 2014 | 05:41 PM
febs1011's Avatar
yes if I need to replace it im going with another recuric bov there was an atmospheric on my sti that ****ed with the idle to much for me to like it....I can feel the air while reving at what sounds like a constant rpm being that im under the hood not looking at the tac im not 100% sure if its climbing or not
Hiboost
75
Dec 4, 2019 05:09 PM
RN3037
Apr 22, 2014 01:44 PM
EvoDan2004
28
Oct 25, 2013 07:58 PM
Jakartaboost
Oct 5, 2013 09:56 AM
PiotrekEvo
Mar 8, 2013 02:52 PM
