MAP Sensor Recommendation
Old Mar 27, 2014 | 08:45 AM
Evo_AK's Avatar
Veteran: Air Force
Hey guys,
Sorry if this has been discussed before. I am currently building my VIII with a 2.0LR and Stage 3 Head from BR w/ PTE 6466. Shooting for an 8 second car. I've seen people max out the Omni 4 Bar at roughly 7xx whp and wondering what would be better to get into the 800 club, the Omni 7 Bar or the AEM 5 Bar? I've heard the bigger the MAP sensor, the worse the response is, but am new to the tuning portion and wanted to see what people recommend. Thanks for any advice!
Old Mar 27, 2014 | 08:52 AM
heel2toe's Avatar
It depends how much boost you are planning on running. Every 1 bar = 14.7psi however I think the first bar is to account for normal atmospheric pressure. Now I'm not positive on this but I believe that is the case such that a 3 bar will only read up to 29.4psi 4 bar 44.1 so on and so forth.
Come to think of it I may actually need to upgrade my MAP sensor as I currently have the 3 bar. I'm in the process of retuning my BBK on e85 and slowly turning up the wick.
If my above statement is indeed correct which I think it is then I will need to acquire a 4 bar. In your case I think a 5 bar should be plenty but I'd wait for someone more knowledgeable to chime in.
Old Mar 27, 2014 | 10:53 AM
okevolutionVIII's Avatar
I wouldn't jump to a 7 bar unless it's hitting boost levels that a 5 bar can't pick up, it doesn't react as fast due to the larger range.
Old Mar 27, 2014 | 12:29 PM
Evo_AK's Avatar
Veteran: Air Force
What's the range on the 5 bar, 50+ psi?
Old Mar 27, 2014 | 12:37 PM
Faisalm's Avatar
Yes, with a 5 bar you should be fine up to 60 psi, no more.
Old Mar 27, 2014 | 12:40 PM
Ev0ikon's Avatar
What's 4 times 14.7?
Old Mar 27, 2014 | 12:49 PM
heel2toe's Avatar
So I take it what I thought regarding how high they read is correct in that the first bar is atmospheric pressure?
Old Mar 27, 2014 | 01:56 PM
Ag4G63's Avatar
Yes the first BAR is dedicated to reading vacuum. Whatever is left reads boost.
Old Mar 27, 2014 | 02:11 PM
R. Mutt's Avatar
Is there any truth to the OP statement regarding "bigger the MAP sensor, the worse the response is"?
Old Mar 27, 2014 | 02:30 PM
Ag4G63's Avatar
If you have 2 sensors, one 5 BAR and one 3 BAR, and they are both 5 volt sensors then yes the resolution will be lower on the 5 BAR sensor. It's just math.
Old Mar 27, 2014 | 04:06 PM
R. Mutt's Avatar
Thanks...that makes sense.
In this sense it's best to use the sensor that best fits the boost range you plan to run. Especially when it comes to data-logging.
Old Mar 27, 2014 | 05:45 PM
Faisalm's Avatar
Exactly
Old Mar 28, 2014 | 01:35 AM
Evo_AK's Avatar
Veteran: Air Force
Thanks for all he help guys. I guess I'll have to switch my order out to the AEM 5 Bar!
Old Mar 29, 2014 | 07:39 AM
Awd>'s Avatar
You should get both, and show your log difs. Then we can all nerd out for the next two years discussing math.
I kid! Hope the 5er works out well! 800... Awesome.
lancerrally45
Jun 5, 2015 07:34 AM
mikgsxx
Jan 22, 2015 07:55 PM
Migsubishi
10
Jan 15, 2015 09:15 AM
Fuchsig
Jan 11, 2015 03:20 PM
