evo 9 turbo installation.
Old Mar 28, 2014 | 09:27 AM
Charlie-Y's Avatar
Hello,
I'm thinking about pulling out my evo8 turbo and put in the evo9 turbo in but wanted to know what is the most challenging part of the removal/installation process?,
and is it necessary to remove the exhaust header ?
much thanks for any feedback or a how to links.
Old Mar 28, 2014 | 09:33 AM
rjfg's Avatar
Yes you will need to remove the exhaust manifold in order to even get the turbo out of the engine pay. This was a fairly straight forward removal and reinstall.
Old Mar 28, 2014 | 09:43 AM
Charlie-Y's Avatar
I was afraid of that, herd when re-install the header it'll need to be resurface both on the header and the engine block.
Old Mar 28, 2014 | 10:18 AM
stvn87903's Avatar
No, you don't. Just replace the exhaust manifold gasket. And the studs if you want.
And although not completely necessary, remove the radiator. I can almost guarantee that you will bump the radiator at least once while trying to get the turbo in / out and the radiator fins bend very easily.
Old Mar 28, 2014 | 11:28 AM
thedru13's Avatar
Pretty easy job.. But if i was you i would drain the coolant and pull the radiator. Gives you a bunch more room.
Old Mar 28, 2014 | 11:36 AM
egis's Avatar
Op but if you have all set up like turbo already connected to exhaust manifold the slap it without dissembling.
Old Mar 28, 2014 | 01:00 PM
slowsrt4:('s Avatar
Remove the radiator or you're going to have a bad time haha, takes minutes to remove the radiator and you won't risk banging it up and cutting the **** out of your hands
Old Mar 29, 2014 | 12:46 PM
Charlie-Y's Avatar
Okay, I got the evo8 turbo out.
I bought the converting kit with the new turbo , however their is no oil pipe ,
The one that connects the turbo to the oil pan. do I re-use that ?.
Old Mar 29, 2014 | 12:55 PM
jrainwater's Avatar
A lot of websites say you are not supposed to reuse that pipe but I did when I put a 20g on my car. It's been fine, just make sure you use new oem washers on the bolts that are on the oil pan side because they have a little rubber seal on each washer that will leak if reused. You might want to put a little grey permatex on the washers too, I did and they have never leaked.
Old Mar 29, 2014 | 12:59 PM
3K's Avatar
3K
Did your kit come with a 9 j-pipe? 'cause the one on the 8 wont work. Most of the conversion kits I've seen don't come with that pipe only the oil and coolant lines.
Old Mar 29, 2014 | 01:10 PM
Charlie-Y's Avatar
Yup, mine came with the j pipe. Anyone have the part number for that oil pan pipe to the turbo?, looks like some of the gasket weld onto it, might end up buying from the dealer ship.
Old Mar 29, 2014 | 01:55 PM
slowsrt4:('s Avatar
you can use the same oil return line but it is a real pain and you have to bend it alot
Old Mar 29, 2014 | 02:20 PM
jrainwater's Avatar
http://www.streettunedmotorsports.co...e_1225a001.htm
Old Mar 29, 2014 | 06:39 PM
egis's Avatar
Op don't be surprised when dealer will ask $7 for paper gasket lol.and yeah you can reuse Evo 8 oil return but be prepared to bend it.good luck.oh,and make sure to chance the gasket on that oil return line that goes from the turbo.cause in case it's leaky and turbo is mounted it's not gonna be fun to replace it.good luck.
Old Apr 3, 2014 | 01:52 PM
Charlie-Y's Avatar
Update!!!
I just finishing up putting everything together , primed the turbo then start the car, smoke starts coming from below the turbo once it warms up followed by clicking noises.
Any suggestion ?
