baffled oil pan or crank scraper?
Old Apr 1, 2014 | 08:00 AM
maknuge's Avatar
Question baffled oil pan or crank scraper?
Simple question here. I am about to install my built engine and looking to make around 800whp. The car is built for drag racing and spirited driving around town. I already installed a kiggly hla regulator in the head. I was wondering who recommends a baffled oil pan (like the AMS one) or a crank scraper (like cosworth) for the extra safety?
Thanks
Old Apr 1, 2014 | 08:10 AM
420a-t's Avatar
I am in the same boat as you. The baffled oil pan IMO would do more than a crank scraper to ensure you're sucking up oil rather than air. With thatvbeing said, I also picked up a cosworth crank scraper as well. I'm trying to find out how to baffle the stock oil pan now as I'm thinking it can't be too hard to do. JUN and Buschur both sell modded oil pans as well.
Old Apr 1, 2014 | 11:53 AM
okevolutionVIII's Avatar
I would do both, the Cosworth scraper is cheap and very well made. If it's using a 88mm crank, it bolts right on without taking hours of grinding and checking tolerances like I did with the 100mm.
Old Apr 1, 2014 | 01:57 PM
maknuge's Avatar
yeah it will be going on a 2.0L long rod motor with factory crankshaft, so it should go in without modification
Old Apr 1, 2014 | 03:34 PM
EvoJoeIX's Avatar
Buschur oil pan and crank scrapper
Old Apr 1, 2014 | 03:35 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
WTF why not both?
My track car is going to get a Tomei crank scraper and this Buschur pan here soon.
HLA is always a good idea.
Old Apr 1, 2014 | 05:41 PM
6466evo's Avatar
can tomie scraper be used with 94mm crank without modification?
Old Apr 1, 2014 | 06:01 PM
420a-t's Avatar
The cosworth one can be (they say, I have not tried it myself) not sure about others
Old Apr 4, 2014 | 11:33 AM
maknuge's Avatar
what about an oil accumulator? In the AMS oil pan product notes, they recommend the moroso oil accumulator.
Old Apr 4, 2014 | 07:55 PM
EvoJoeIX's Avatar
Thats more geared towards road racing
bryonboals
Feb 23, 2017 03:50 PM
David Buschur
83
May 27, 2016 07:39 AM
crazy_ugly_coyo
15
Sep 29, 2015 07:53 PM
RalliartN
31
May 6, 2015 11:39 AM
tscompusa2
Nov 12, 2011 02:57 AM
