How G-Force affects the oil in your pan.
Old Apr 5, 2014 | 09:17 AM
Pure EvoIX's Avatar
so you were drag racing? So it was a longitudinal G for maybe a 2 sec, then you would shift oil will slosh back and forth, the the longitudinal G would taper down to i dunno .6-.7G continuous? I am holding a lateral 1.2-1.3G for 6-10s.
Old Apr 5, 2014 | 10:15 AM
94AWDcoupe's Avatar
Yes this was in a straight line. It did 1.3g in first 1.1g in second and .9g in third. 0-112 in 6.66 seconds. have no data on oil pressure losses during slosh, but they certainly must have been there. it was a street car so suspension was compliant. car lifted enough to drag the exhaust pipe in the rear.
Old Apr 5, 2014 | 10:35 AM
Dave W.'s Avatar
and holding it at 5k rpm.
Oil pump output is directly related to engine rpm. Oil is pumped out of the pan faster at high rpm, and if you're holding high G's at the same time the oil will pack up on the side of the block/head instead of draining back down to the pan.
FP is on the right track when they point out that at .7G the oil stands at a 30* angle in the pan. At 1G the oil stands at 45*. At 1.3G cornering force the oil stands more vertically, add an extra 2* for body roll and the oil is approaching 55*! At that point on a hard right hand corner the oil is almost entirely pooled in cylinder #4. This is why the hardcore RR guys use dry sumps. You need a separate pump to bring the oil back to the pickup tube.
Old Apr 5, 2014 | 11:31 AM
420a-t's Avatar
Has anyone done a test to see how much extra oil can be added in the pan safely without the crank hitting the oil level and creating bubbles?
Old Apr 5, 2014 | 12:12 PM
deylag's Avatar
Great info! I dont do track events but I am glad that I have some oil control already with the Kiggly HLA, Buschur Baffled Oil pan, and Cosworth Crank Scraper.
Old Apr 7, 2014 | 12:19 PM
leecavturbo's Avatar
Ah Shuks, I read the title and thought a viable non ds fix was inside.
Old Apr 12, 2014 | 10:53 AM
420a-t's Avatar
Trying to see what oil pressures people have now when launching with all these "fixes" (aka buschur oil pan, crank scraper, kiggly hla) out there besides a dry sump. I've been trying to find data as far as pressure goes and it seemsno one monitors oil pressure after these fixes are installed.
Good info, FP!
kaj
316
Oct 30, 2024 09:16 AM
Abacus
Mar 21, 2017 07:10 AM
David Buschur
83
May 27, 2016 07:39 AM
SWOLN
Jan 29, 2013 04:25 PM
Timebombxxx99
Mar 1, 2009 11:34 AM
