Okay! My evo 7 turbine broke snap in pieces and it's on the exhaust side just wanted to know if I can drive my car in the mean time while i get my other turbo
If it isn't leaking oil then you are probably fine. If it damaged the bearings and such you would not want to drive like that. I had a friend who his turbine wheel snapped off clean and didn't mess up the compressor or bearings. He just had no boost.
I have no boost and it's not leaking any oil so I guess I should be fine then? Just for Afew more days
Quote:
+1Originally Posted by batty200
if it isn't leaking oil then you are probably fine. If it damaged the bearings and such you would not want to drive like that. I had a friend who his turbine wheel snapped off clean and didn't mess up the compressor or bearings. He just had no boost.
