turbo question
Old Apr 22, 2014 | 03:41 PM
Evv007's Avatar
turbo question
my evo 7 turbo broke and i picked up a td05 16g6 10.5t whats the difference between the stock turbo in the evo 7 and this one? i got my tune done awhile back on the evo 7 turbo that broke and was wondering if i needed another tune for this turbo? or i can just put the new turbo i got in and should be all okay?
thanks!!
Old Apr 22, 2014 | 03:48 PM
Faisalm's Avatar
It does flow a little more than the 9.8 but really you should be just fine running it without a tune.
Old Apr 22, 2014 | 05:00 PM
slowsrt4:('s Avatar
you will need to bend your coolant lines to get it to fit, it will make a good amount more power than your old turbo. you will also need to get a different J-pipe for the lower intercooler pipe to connect correctly.
Old Apr 22, 2014 | 11:38 PM
Evv007's Avatar
Turbo!
That's cool! We'll my evo 7 is at 182kilowatts now and what do u recon I could achieve with another tune and also how much more can it handle in kilowatts how much further can I go!
Oh and 2001 evo 7
Thanks!
Old Apr 23, 2014 | 12:05 AM
Faisalm's Avatar
Oh and 2001 evo 7
Thanks!
It's not the kilowatts / horsepower that will destroy a stock block, it's the torque / Nm. In terms of kilowatts, there are people achieving 450+ kW (600 hp) on their stock blocks, but they would control the torque to around 400 ft/lbs (~540 Nm) to keep the stock internals happy.
I'm guessing since you're in Australia your modifications are minimal due to your restrictive laws. Minor bolt-ons? If yes, then I'm presuming around 420 hp (~320 kW) would be possible on pump gas.
Evv007
Apr 1, 2014 11:58 PM
DevilDog7
Nov 16, 2012 07:28 AM
Xday_dreamrx
Midwest Region
14
Jul 30, 2012 03:31 PM
RREvoxGSR
May 13, 2011 03:37 AM
Enjoi411
Dec 4, 2010 01:46 PM
