Evo 9 blue smoke, oil on spark plugs!
Old Apr 24, 2014 | 08:25 AM
SeahawksOilers's Avatar
So my evo 9 starting puffin blue smoke while accelerating. Now during idle as well. And runs very rough. Also when reving up it blows out more. Definitely burning oil as the level went down. Took out spark plugs and there was oil on the threads of all of them. Did a compression test also:
Cyl1: 128
Cyl2: 130
Cyl3: 141
Cyl4: 135
Not quite sure what the problem could be!
Old Apr 24, 2014 | 09:41 AM
slowsrt4:('s Avatar
if you have oil on your plugs then it is your motor, possibly a crack in a piston or valve. no bueno. those compression numbers are low also but I don't see a large difference between the numbers, but with those numbers you would likely need to do a rebuild when you have time anyways, goot numbers should be around 170-180 if I remember correctly
Old Apr 24, 2014 | 09:52 AM
bbong's Avatar
Your compression numbers seem to be all over, engine may need to be refreshed.
Old Apr 24, 2014 | 10:37 AM
adriano_917's Avatar
sounds like piston rings to me...
Old Apr 25, 2014 | 07:46 AM
If it was a piston or ring, or even a crack wouldn't that be affecting only one cylinder tho? Not every one?
Old Apr 25, 2014 | 07:47 AM
Could it be all piston rings at the same time tho? Isn't that something that would happen to only one cylinder?
Old Apr 25, 2014 | 09:30 AM
boost556's Avatar
I have similar prob but my compression are 165 to 155 across the board. I was advised it my valve seals so I am about to get my head build with new valve seals, springs and retainers.
I am running the s2 cams but still have stock springs and seals so was told that was what cause my problem.
Old Apr 25, 2014 | 09:31 AM
boost556's Avatar
Mines throw blue smoke on start ups and light sometimes at idle, but no smoke on the highways.
Old Apr 25, 2014 | 10:00 AM
silver03evo1's Avatar
Make sure you do all tests. Mine did something similar to this awhile back and
it ended up being bad valve guides.
Old Apr 25, 2014 | 10:02 AM
Old Apr 25, 2014 | 02:48 PM
bbong's Avatar
Your numbers are scattered and low, it could just be wear on the engine and needs a refresh. How many miles on it? You can also do a leakdown and see what it is.
Old Apr 25, 2014 | 09:24 PM
Not necessarily all pistons are being used at the same time theyre just worn out, are you having too much blow by through the oil cap ? The compression numbers look low but they are not to separate from each other 10% or less which is not bad but low. Your best bet is to do a leak down test. Remember tdc at compression stroke.
Old Apr 26, 2014 | 09:11 AM
It's got about 85000miles. Also like the engine was completely cold when I did the compression test. So it might be a bit higher if the engine wasn't completely cold.
lowboost
17
Apr 11, 2018 03:38 PM
ISPEVO8
Feb 27, 2017 07:01 PM
plan:b
Dec 25, 2015 09:07 AM
Tarvi Trees
Nov 16, 2015 03:11 AM
Throttle
20
Jan 21, 2012 07:41 AM
