Fuel Injectors/ Turbo
What is the upgraded turbo size that requires the modifications of fuel injectors and fuel pump? Wondering what has to be done for all of them to work together properly. Thank you
on an evo 9 you can make good power on the stock pump, but I would recommend a walboro 255 even if you're on stock 9 turbo. I would also change injectors to 1000s if you plan on keeping the stock turbo, 1200s or larger if you plan on doing e85
blkdrgn09
Jun 12, 2015 09:27 AM
evovin
Mar 29, 2008 08:27 AM
