stock injectors
Old Mar 12, 2004 | 07:46 PM
BenM's Avatar
Originally posted by Deceit
you're thinking of a narrowband?
i know that there are narrowband a/f's like this but i was asking if there is one that is wideband... i want it to be just a circular gauge. not the box style one.
do you guys think it'd be alright if i just put a narrow one in and just watched to make sure it didn't go in lean?
Thanks
Ben
Old Jul 3, 2010 | 10:17 AM
Dowve's Avatar
hmm interesting
Old Jul 3, 2010 | 10:40 AM
dan628's Avatar
I run the stock injectors with stock turbo and kelford 272's and made 353AWHP / 354 torque tuned by AMS.
Old Mar 17, 2011 | 10:04 PM
10isace's Avatar
What's your injector duty cycle?
Old Mar 18, 2011 | 05:54 AM
henrys's Avatar
Originally Posted by Zeus
What's the duty cycle and fuel pressure at this power level though? I'm afraid of the wear and tear on the injectors and fuel pump if this comes from high duty cycles and high fuel pressure. Throw some numbers at us David. My right foot rests on the firewall daily
Not to argue but I don't see how duty cycle hurts an injector. At 100% they are held open which would probably cause more heat soak into the injector but its not that much. Hondata tested this and with stock low-z injectors with a resistor box the injectors only reached 40c being held open for 3 minutes
However, my concern with high duty cycles is the ability for the ecu to increase pulse width further to compensate for environmental conditions. Example if you tune for 90% duty at 70 degrees and then you try to run it hard in 30 degree temps you're probably going to max out the injector and could run lean. It doesn't give you enough head room.
Old Mar 18, 2011 | 06:15 AM
Zeus's Avatar
We've ALL learned a little about this subject in the last 7 years... since that post.
...I'm just sayin'
Old Mar 20, 2011 | 09:14 AM
henrys's Avatar
...I'm just sayin'
Doh, didn't realize how old the post was.
Old Mar 20, 2011 | 10:25 AM
Danner's Avatar
Originally Posted by davidbuschur
The stock EVO injectors are 560 cc actually.
We have made 361 whp and 303 ft lbs. The car ran a 12.09 at 115 mph on 94 octane like this.
The stock injectors with a pump upgrade should be able to make over 400 whp in the car with the correct tuning.
David Buschur
www.buschurracing.com
Thank you.
Any more, you really have to run a comb through some of the posts people make on here.
Old Mar 20, 2011 | 01:28 PM
saxon's Avatar
I made 330 on stoc pump/injectors and my duty cycle was 110%
Just a walbro should help increase that but your still pushing your limits
Old Mar 20, 2011 | 01:32 PM
ev1levo's Avatar
Upgrade em to some 1000cc
Old Apr 16, 2011 | 02:30 PM
106rallye's Avatar
Can someone help me cause I am a little confused.
I have an EVO ix with stock turbo,stock injectors plus kelford 272 and walbro 255 pump.
My tuner tuned the car in a maha lps3000 dynometer and the car made 440 at the crank with 1.8(27 psi) over tapering to 1.55(23 psi) at 8000 rpm.
The afr is 11:1 from 6000 all the way to redline.
I do not know the injectors duty cycle.
Today a friend of mine tuned his car. Same specs but without the cams. Same fuel same everything but another tuner. At the same boost level and with afr 11.8:1 the tuner told my friend that they run out of fuel.
Is this possible?
With out cams and already maxing stock injectors?
What is the horsepower stock injectors can deliver;
Thanks.
