is it normal for air to escape wga during boost leak test?
Old May 2, 2014 | 06:21 AM
charlie.tunah's Avatar
Ive searched and most say to cap the line from the turbo j-pipe, but I swear Ive never done this with my ebc installed and its always worked fine.
Right about the time I get to 14psi, I get a lot of air escaping through the wga can. If I pinch the line going to the wga, it stops.
Is this normal? Should I have to cap the line from j-pipe?
Old May 2, 2014 | 06:44 AM
scratch that...I just hooked up my other actuator and get no air escaping. Looks like Im swapping actuators.
Old May 2, 2014 | 12:44 PM
slowsrt4:('s Avatar
so your wastegate was leaking, strange. good to know though
Old May 3, 2014 | 01:09 AM
Yes. It was leaking out the can. All of the "How to Boost Leak Test" write-ups say to plug the boost signal line. So you'd never know if the can was leaking. But I had never done that since installing my bcs and never had this problem. Definitely does not leak out of the oem ix actuator that I have. I gained close to 40whp/30wtq (VD) after swapping actuators yesterday... And now I have full control over the boost curve.
seven10
Nov 29, 2016 09:42 PM
vr4gasmtt
Jan 7, 2015 12:56 PM
EvoRinga
Mar 12, 2012 07:39 PM
ch1215g
Feb 5, 2011 12:08 PM
Ian0611
Oct 19, 2010 09:18 AM
