2618 or 4032 pistons
Old May 2, 2014 | 08:42 PM
Charlescrown's Avatar
This has probably been discussed before but I need to make a decision with an engine repair. The car is EVO4 and only for track use running 7 injectors and ECU and 15lb boost. I cracked all the ring lands off between the top and second compression rings. I know it's detonation but since I am repairing I am looking for advice on peoples past experiences with these 2 piston types. I want about 350HP at flywheel so not expecting big power but also want reliability as this car has the accelerator to the floor or on the brake no in between.
Old May 5, 2014 | 09:04 AM
JohnBradley's Avatar
4032 doesnt expand as much vs heat and can be run with slightly tighter PTW. We run 2618 Wiseco in our builds.
Old May 5, 2014 | 01:15 PM
LetsGetThisDone's Avatar
2618 is somewhat softer/malleable, which makes it more resistant to damage from detonation. Definitely a better choice for our FI engines...
Old May 5, 2014 | 01:58 PM
I went for what I could get and settled for 2618 Manley. The reason being is the others required honing the cyl to clearance and I wanted them to fit std bore. I couldn't find much info about Manley but I didn't find any negative comments also. They will arrive in Sydney on Monday all going well.
babaz7
Feb 22, 2015 12:02 PM
mouseIX
12
Aug 30, 2013 01:34 PM
YaroRS
Oct 31, 2011 08:14 AM
TTP Engineering
335
Jun 9, 2010 11:49 AM
turboj
Aug 20, 2007 03:19 AM
