new set up now fuel pump wont turn on
Old May 16, 2014 | 06:15 AM
N1ck Z's Avatar
Exclamation new set up now fuel pump wont turn on
so i just went through a entire new set up tested the pump before installing and at ignition the pump wont prime... completely dumb founded because i didn't touch anything that would cause this to happen...
hoping its something easy that i just forgot
please chime in
Old May 16, 2014 | 06:17 AM
ak47po's Avatar
New setup helps a lot.
Old May 16, 2014 | 08:51 AM
LetsGetThisDone's Avatar
These cars don't prime. The pump only comes on when the engine is cranking, or running...
Old May 16, 2014 | 06:36 PM
egis's Avatar
need better ground.
Old May 16, 2014 | 06:38 PM
meckert's Avatar
so stick a hose on the outlet side and Suck----that will prime the pump and if you had connected it correctly-- it will prime and pump fine.
Old May 18, 2014 | 12:06 PM
N1ck Z's Avatar
The pump was air locked..
Thanks for you imputs guys! Got the car to the dyno on time too
pennies_hatchie
68
Mar 5, 2023 08:02 AM
xceler8rob
34
Jul 17, 2016 12:57 PM
BoostNY
12
Jan 10, 2016 05:12 PM
turboback1243
May 19, 2015 12:41 PM
amsevokid
14
Apr 21, 2014 11:59 AM
