Wastegate actuator advice needed
Old May 22, 2014 | 05:01 PM
Biggy VIII's Avatar
Hi mates,
My FPGreen 73hta BB suddenly couldn't boost any more than 7 psi and spooled very-very lazy. Trying to find the problem, I pulled the actuator rod with my hand to check if there was any free play and it just came out of the canister freely. I took off the actuator from my turbo and it just felt apart in my hands in two pieces - the canister and the rod. The rod was fine and had a nut on its end, the one that keeps it together with diaphragm. When I looked inside the canister, I saw that the hole in the center of the diaphragm has become big enough so I could push the rod with the nut on it in place and take it out almost without any force. Looked like the rod has worn out that hole in the diaphragm and popped out of it. I replaced it with a new one FP 18psi, but the new one has broken the same way half a year later. So I had the same problem twice...
Both of them where bought new, never damaged, installed and preloaded to a standart preload, according to the video recomendations on FP site.
Now I need a new actuator, again... But FP 18psi is not listed on their site anymore. So which one would you advice - Turbosmart, Forge, etc...?
Any advices\comment are welcome. Thanks.
Old May 22, 2014 | 05:09 PM
VIIBHR's Avatar
Turbosmart looks more quality to me, i am leaning towards it since im in the look for a new actuator also.
My stock turbo is acting the same cant boost more than 5 psi! But i didnt pull my actuator and check it out.
Old May 22, 2014 | 05:24 PM
Biggy VIII's Avatar
Yes, I like how it looks. But I have found an info that it may be not as durable as it looks like. The aluminium locking collar tend to strip\wear out the threads from the first opening. Wanted to hear some more info...
Old May 22, 2014 | 07:04 PM
CDrinkH2O's Avatar
Turbosmart is the business. I upgraded 30,000 miles ago from the FP 18#. The engineering is top class and ive had no issues with removing the top and changing springs multiple times. Get it. You wont look back.
Old May 23, 2014 | 04:09 AM
Biggy VIII's Avatar
Thanks for advice!
Any other opinions about other actuators?
Old May 23, 2014 | 04:42 AM
slowsrt4:('s Avatar
If you email fp they might have some 25 psi actuators
Old May 23, 2014 | 05:01 AM
Biggy VIII's Avatar
I emailed them. waiting for an answer.
I believe 25psi would be too much, as I am running 25psi peak boost, tapering to stable 22-23 till redline on my 2.3l. More than that I would like to be able to control lower boost levels. So 18 psi was my choice.
Old May 23, 2014 | 05:04 AM
egis's Avatar
i have kinugawa 25psi can't complain.
Old May 23, 2014 | 07:09 AM
Biggy VIII's Avatar
Do you have the "Billet Adjustable Turbo Actuator Mitsubishi EVO 9" or "Mitsubishi EVO 9 Green Red TD05HR TD06SL2 TD06H" one?
Old May 23, 2014 | 08:29 AM
egis's Avatar
Biggy VIII i have stock 9 turbo but these wga will fit any stock frame turbo.
Old May 24, 2014 | 02:26 PM
sparky's Avatar
Originally Posted by Biggy VIII
…..I believe 25psi would be too much, as I am running 25psi peak boost, tapering to stable 22-23 till redline on my 2.3l. More than that I would like to be able to control lower boost levels. So 18 psi was my choice.
I would say try the FP 25# actuator. That is what I will be getting for my CBRD 3-B eventually and I plan to be running about 23-25# peak. I had already purchased one but I let a sneaky-sneaky Ratsbud talk me out of mine.
Old May 24, 2014 | 02:50 PM
ECN-GSR's Avatar
well to get a better idea of whats going on: Boost/peak boost setup, EBCS/MBC settings, tune(?) and if a boost leak was performed/found.
Old May 24, 2014 | 02:58 PM
Biggy VIII's Avatar
25-26psi peak boost, tapering to stable 22-23 till redline, using 3-port solenoid, well tuned stock ECU, 2.3l engine, no boost leaks, no problems at all. FP actuator bit the dust.
Old May 24, 2014 | 09:49 PM
eckok24's Avatar
Bump
Old May 25, 2014 | 12:34 PM
Biggy VIII's Avatar
Any other advices?
