Dead COP
Old May 26, 2014 | 04:56 AM
french's Avatar
Dead COP
Has anyone had or heard of a coil pack dying almost immediately after install.
The COP was a genuine denso of a reputable seller it died during it's first drive.
I have checked the resistance between both ground and trigger also between ground and power and compared against working COPs and nothing seems out of the ordinary. It just won't spark.
Could there be any other causes?
Old May 26, 2014 | 05:46 AM
meckert's Avatar
Yep, had same issue with a coil from toyota---thought it was my problem with no spark on one cylinder. Replaced coil, nothing, no fire. traced the wires back to the connector for the harness and guess what--it began to fire. One of the wires wasnt tight in the connector.. Good luck
Old May 26, 2014 | 06:12 AM
french's Avatar
I have tried having the COP in a different position. It was originally in 1 but know is in 2. So a completely different set of plugs and wiring. No spark in either position.
I should mention it is a evo viii.
Old May 26, 2014 | 11:57 AM
meckert's Avatar
Sounds like a bad coil my friend--- it happens.
Old May 26, 2014 | 06:36 PM
french's Avatar
Seems it is dead. All good supplier has hooked me up with a new one.
timmycat
Sep 21, 2015 09:37 AM
2006GSR
11
Jul 9, 2015 08:35 PM
littlegif1
Apr 6, 2015 07:48 PM
Evo11V
Mar 14, 2014 07:58 PM
ZeRoMaX
Mar 12, 2014 08:57 AM
