Kevlar belts - change interval?
Hey guys,
20+ yr DSM vet but I've never used an aftermarket Kevlar t-belt.
Assuming all components (seals, gaskets, water pump, tensioner, pulleys) changed at the same time, would it be safe to schedule the next job 120k miles out?
I would think so, or else why pay +$200 for a belt anyway??
I wouldn't suggest running a Kevlar belt unless the vehicle is used for racing where running time is minimal ie; drag/circuit racing. Daily driving I would stick with oem belt which always for expansion and less stress on the hydraulic tensioner
Good point, I had not thought of those consequences.
I've run both the Gates Kevlar and OEM belts to 60k of Daily Driving
Both swaps the timing components looked just as good as the day I put them on.
You'll be fine with either, I'd still follow manufacturers recommendation for belt replacement no matter which you choose
My point here is why do aftermarket Kevlar belts exist? Are people using them to increase their change interval, or are they simply to handle the added increase in higher strength valve springs some of us may be using?
Pulleys and tensioner rarely fail within the first 120k miles in my experience. So if the only real weak point is the OEM belt, maybe these aftermarket racing belts can help us extend the change interval.
Anyone with real/personal experience?
Extending timing belt change interval is well dumb. If you like to play in the fire go for it, but whether running a Kevlar belt or OEM anyone I have ever talked with and myself have always followed the same change interval
I wouldn't change a belt without doing all timing components at the same time. I don't care what they look like coming off.
Couple hundred vs couple thousand
No brainer
No brainer
Ok , I think I'm not expressing myself clearly
I've always replaced my belts in all my Mitsubishi's every 60k. I'm not saying it's smart to wait until 120k.
I'm asking what is the point of the aftermarket Kevlar belts?
So are people actually buying them, and if so, why?
I have 60k on my Kevlar belt and don't plan on changing it anytime soon. I do check the belt regularly. It is not wearing at all. The benefits are longer service interval and better accuracy of valve timing. It is actually less work on the tensioner if the belt doesn't flex or stretch. It is not a bad idea to swap it at regular service interval though.
I was told that the main reason for the Kevlar timing belts were for those running aggressive aftermarket cams. The few aftermarket Kevlar belts seem to look and feel just as stiff as the oem one though, minus the variations in colors offered.
Apart from my Kevlar timing belt I also had at one point a Kevlar serpentine belt. The colored finish wore away really fast even though the the timing belt stayed brand new, go figure, they were from the same manufacturer. I used it for curiousities sake, but I ended swapping it out for a regular Gates belt. I deleted the a/c so that belt wouldn't work anymore.
I have to hand it to Mitsubishi for sticking to the 60K recommendation. My Subaru's timing belt interval is 105K but the mechanics say there's a sprocket that often fails before that mileage. Two heads, four cams that have to come off before you can reach the head bolts and you have to pull the engine if that sprocket goes. Not nice.
AWD_Terror
24
Apr 8, 2011 07:48 PM
Hcaruso4
29
Sep 26, 2007 04:23 AM
