Mild Head Build - Evo 9
Old Jun 10, 2014 | 12:07 AM
JDMevoBOOST's Avatar
Haven't checked in on EvoM in a while. Valves started leaking so decided to do a mild head build.
Car is mainly for street duty and HPDE. Not looking to make more power, hoping just to make it more reliable. Let me know what you think about the list.
Car:
2006 Evo 9
45K miles
430 whp/370 wtq on GST Mustang Dyno
BBK Full on E85
Machine Work:
Clean
Inspection
Multi Angle Valve Job
Deck
Parts:
Kiggly Beehives
Kiggly HLA
MAP Black Nitride Valves
Supertech Valve Seals
ITM Lifters
Ferrea Valve Guides
ARP Standard Head Studs
Extras:
MAP Setrab Oil Cooler Kit
FIC 1450
Deatchwerks DW300
Is there anything else that I should add while I have the head off?
Thanks,
Ken
Old Jun 10, 2014 | 08:26 AM
andrewzaragoza's Avatar
looks good. i would suggest adding Kiggly HLA.
Old Jun 10, 2014 | 01:36 PM
RSGuy's Avatar
Don't forget timing belt kit. You might as well do your 60k service if you're pulling the head off
Old Jun 11, 2014 | 03:44 PM
Forgot to mention i bought the oem timing and water pump kit along with the full gasket kit from mitsu.
Does anyone else think the kiggly hla is something i should look into?
Old Jun 11, 2014 | 04:39 PM
Faisalm's Avatar
It's a very good investment. I would definitely purchase one.
Old Jun 13, 2014 | 07:33 PM
Okay Kiggly HLA purchased. Thanks to Nate@Map for all the goodies. Anything else I'm missing from the list?
Trying to talk myself out of not replacing the cams...never really liked my Cossie M2's though.
Old Jun 17, 2014 | 08:19 AM
mrfred's Avatar
suggest fic1100s or asnu1050s over the fic1450s at your power level. they are a better injector and are big enough for your power level. next, i would go with a walbro 450 over the dw300. the dw300 will be close to its limit while the w450 will be well within its flow range.
aggieEVO
Sep 7, 2019 10:34 AM
420a-t
26
Feb 22, 2017 11:49 PM
Skidonner90
17
Aug 29, 2016 06:08 PM
ReivaXVrai2
15
Nov 28, 2015 11:42 AM
eliaslear
Sep 24, 2015 07:28 AM
