oil light lifter tick
Old Jun 14, 2014 | 08:26 PM
CT9A PR's Avatar
Ived owned 3 Evos....
All have had issue with the oil pressure sensor so this was ignored. Car had a lifter tick at 3000 rpm which then was heard at 2500 1500 and idle. Oil light was flashing but dimming out.
I thoughr the worst and thought the bottom end was shot eventually. We check the oil and there is zero metal in the oil. We take off the valve cover and all lifters are dead. Has this happened to anyone?
Old Jun 16, 2014 | 07:59 PM
subaru606's Avatar
yes its most likely your sensor . its easy fix for only about 7 bucks
Old Jun 17, 2014 | 03:39 AM
CT9A PR's Avatar
tick is bad and car wants to show off
pump went bad too I think but am I lucky the block didnt go too?
Old Jun 17, 2014 | 05:16 AM
batty200's Avatar
Sounds like bad things are going on. Pull the pan and inspect the bottom end.
Old Jun 18, 2014 | 05:52 AM
CT9A PR's Avatar
Oil squirter went loose
Old Jun 18, 2014 | 05:02 PM
drive955i's Avatar
Pull a couple of camshaft bearing caps and make sure the metal isn't galling. The bottom end likely did not starve for oil, but maybe the top end has. You don't want to assume it's okay without checking it out.
Hope they're in good shape.
Old Jun 18, 2014 | 07:41 PM
batty200's Avatar
That would cause low oil pressure! Glad you found the issue. Hopefully it was before any damage happened.
navr11
Mar 6, 2016 07:06 PM
hutch959
Dec 27, 2015 03:43 PM
evoxsi
140
Jun 16, 2013 01:02 AM
Evolution 8 MR
Dec 1, 2012 11:53 AM
shadow1
Dec 13, 2011 11:33 PM
