Crank or cam sensor causing this problem??
Old Jun 17, 2014 | 05:12 PM
bwanner's Avatar
My 03 threw the p0335, no crankshaft reference signal at efi ecu. My car starts and runs at a higher rpm than normal at cold start. After about 5 minutes of idling at a higher rpm it starts to misfire and dies out. It won't start up after a warm up. I read up that if it's the crank, my car won't start and I won't have fuel and spark at all. So that leads me to thinking it's not my crank sensor. Why would my car run fine at a cold start but a higher rpm but throw that code? Is it my cam sensor? It's a built motor on speed density.
Old Jun 17, 2014 | 06:19 PM
Biggiesacks's Avatar
It could be a bad sensor that has a thermal break. When it gets hot it stops working properly, cools down and works ok again. Happens alot with electronics.
pennies_hatchie
68
Mar 5, 2023 08:02 AM
whatever210
Oct 19, 2015 07:18 PM
Wmu240
Sep 8, 2015 06:21 PM
Boosted_EvoVIII
59
Jul 1, 2014 10:56 PM
batty200
Apr 22, 2014 05:11 AM
