Crank Walk, Fuuuuuuu!!!
Old Jun 26, 2014 | 03:49 PM
ms32evoixmr's Avatar
Originally Posted by Faisalm
What in the world... "Most likely it did" just doesn't cut the mustard... Show me pictures, show me evidence of this, not "most likely it did"....
Hi highly doubt they kept it. Must have recycled it or what not. Not going to drag it on any longer. The car is leaving tomorrow. No one offered to have me come by to see the oil after they had drained it.
Old Jun 26, 2014 | 03:51 PM
Originally Posted by TSiAWD666
They might be giving you the run around as checking for walk is very easy to do. Using a prybar on the crankshaft bolt you force the crank all the way to the driver's side of the car, and then have someone depress the clutch. Usually you would have a dial indicator set up on the crankshaft bolt side, magnetic base hanging from the frame rail, zero'd out with the crank on the driver's side, and measuring play when the clutch is fully depressed. In your case, if they are telling the truth of .25" you wouldn't even need the gauge as that level of play is absurdly high and of course very visible.
I really doubt your car would be running with .25" of play as that would have taken out your crank position sensor a long while ago.
That's what i told them. By they kept saying its not true, it depends on the severity of the walk. At this point, i'm not even going to bother. Just wanted to get my car and have someone else inspect the crank. We shall see.....
Thank you for your insight. Highly appreciated....
Old Jun 26, 2014 | 07:00 PM
evolve_VIII's Avatar
Do you have any mechanically inclined friends that can check this?
Either way I dont think your crank walked. It is extremely uncommon on an evo. They may have been trying to get you due to that it used to be a common issue. If your crank didnt walk, call the BBB and report it. We dont need shops like that ripping people off thousands of dollars.
Im glad you caught them in their lie and Im glad you got a second opinion on here!!
Old Jun 26, 2014 | 07:30 PM
Faisalm's Avatar
What boggles my mind is that the OP states that this is a well known EVO and GTR shop, and they have the fastest (?) Evo in California... That shouldn't be so difficult to narrow down...
Old Jun 26, 2014 | 07:49 PM
wreckleford's Avatar
Why is everyone jumping on the shops case? Likely the OP got the crank endplay measurement wrong as someone else mentioned.
If I was working on a car and measured endplay of 0.025" I wouldn't bother to check the oil for metal shavings. Once the endplay is out of spec you have a problem. End of story. It's not as if endplay can be out of spec but since the oil looks clean then it's all good.
You can have crankwalk and not know. The first sign maybe the sound of the crank trigger brushing the sensor. This is not such a loud and horrible noise and it can happen for a little while before it takes out the sensor.
Before you move your car, go down there and look at the endplay for yourself.
Old Jun 26, 2014 | 10:49 PM
mrfred's Avatar
all sounds good to me.
kaj
17
Jul 20, 2016 08:03 PM
lunchbox23
Jun 12, 2014 06:19 PM
Coxor
14
Aug 24, 2013 11:02 AM
CrawlinTBSS
Dec 22, 2011 09:15 AM
lan_evo_mr9
30
May 25, 2011 09:47 PM
