Car starts to overheat when boosting
Old Jun 30, 2014 | 05:04 AM
xxevo8xx's Avatar
The car starts to overheat on the temp gauge when it reaches over 2.5k RPM. What kind of problem could this be?
Old Jun 30, 2014 | 07:11 AM
way2qik's Avatar
Blown headgasket and/or weak/stretched cylinder head bolts. When pressure is put into the cylinder it may be slightly lifting the cylinder head which allows combustion to pass into the cooling system. In effect, this super-heats the water and causes a spike in temperature. Once you let off the head sits back down and the system cools off. This is my best guess without knowing anything else about your car and its set-up. Hope this helps.
Old Jun 30, 2014 | 08:34 PM
MRfabolous's Avatar
sounds like a head gasket problem just like way2qik said where are you located.
Old Jun 30, 2014 | 10:14 PM
Biggiesacks's Avatar
Have you checked your coolant level?
Old Jul 1, 2014 | 05:20 AM
xxevo8xx's Avatar
Ah it might be the head gasket, one day when I was parked it was leaking some kind of oil mixture with coolant, but then I wouldn't know how to confirm this. But then again I hit a bump and somehow when I bumped the front bumper I think I cracked the radiator because the coolant leaks out every time I put new coolant in. I live on the east coast, US, in MA.
Old Jul 1, 2014 | 05:21 AM
xxevo8xx's Avatar
When I start the car the intake manifold also gets super heated as well, and sizzles...
Old Jul 1, 2014 | 03:32 PM
So your coolant leaks out as soon as you put new coolant in? Seems pretty obvious that you need to fix your coolant leak. The fact that you are asking why your car overheats, when you know that coolant is leaking out of your radiator......you better take your car to some professionals.
Old Jul 2, 2014 | 02:55 AM
xxevo8xx's Avatar
Well I was wondering if maybe it was just more than a radiator problem, I am inexperienced in automotive repairs but after reading around and getting some help from here I may have an idea of what kind of problems will need fixing and will have a professional take a look. Thanks for the input though.
Old Jul 2, 2014 | 07:18 AM
94AWDcoupe's Avatar
cooling system works under pressure. the pressure on the water raises the boiling point. with a rad leak the system will never pressurize.
Old Jul 3, 2014 | 06:50 AM
xxevo8xx's Avatar
Ah that makes sense, now I understand how the leak affects it much more than I thought, so the head gaskets might still be OK.
Old Jul 3, 2014 | 07:10 AM
xxevo8xx's Avatar
Another problem I have is that when I start it up if I don't give it a little gas it will stall out until I wait a few minutes, and also idles strangely; this is especially worse in the winter.
J Woody
Jul 7, 2022 07:19 PM
casey oc
Mitsubishi TC-SST Discussion
26
Mar 11, 2022 04:49 PM
dubbleugly01
41
Sep 23, 2016 12:07 PM
LancerOZDude
Lancer Troubleshooting
Oct 7, 2014 02:50 PM
TheBigD
11
Mar 7, 2014 07:08 AM
