after MBC install
Old Jul 1, 2014 | 10:48 AM
febs1011's Avatar
after MBC install
i have a hallman MBC ordered. kind of a dumb question but i cant find any answers to my question. when installing the hallman do i leave the oem electronically connected, and only move the hoses? or disconnect it completely? i am asking because i am not sure if disconnecting it will throw a check engine light code.
Old Jul 1, 2014 | 11:03 AM
evobros's Avatar
I left mine connected. Just unplugged the vaccum lines I needed.
Old Jul 1, 2014 | 11:07 AM
oscarquinones's Avatar
live it connected
Old Jul 1, 2014 | 11:09 AM
febs1011's Avatar
i figured i should leave it connected thanks for the advice
Old Jul 1, 2014 | 02:50 PM
slowsrt4:('s Avatar
leave it connected, make sure to run a new vacuum line because the stock one has a boost pill which will restrict the boost level
Old Jul 2, 2014 | 05:54 AM
sparky's Avatar
Why would you need the factory boost/vacuum hoses if you are going to install an MBC?
Old Jul 3, 2014 | 12:55 AM
sparky's Avatar
dump the factory boost/vacuum hose assembly in the trash. Run a new 4mm hose from your boost reference source to the bottom port on your MBC and second hose from the side port om your MBC to th e WGA nipple. Done
badev0
Jul 7, 2015 06:24 AM
silver9mr
Apr 7, 2008 06:30 PM
ModifiedMR
15
Oct 27, 2006 12:38 PM
sneakychaos
May 13, 2005 04:56 PM
BigLEVO
Apr 9, 2005 07:42 AM
