Best fuel pump for race gas?
Hey all, I'm looking for input from some of the guys here who are running race gas (VP C16, etc.). I plan on running pump gas for regular driving and race gas for kill mode. No E85 will be used. What pump out there is capable of supporting up to 750hp and is safe to use with both fuels? I've done some searching but can only find info on the E85 compatible pumps.
Thanks guys
Thanks guys
Hate to jump on the e85 bandwagon but dude you live in Long Island...my ex was from Long Island and the only two things I liked about that place was the pizza and the availability of e85. There are like over 60 stations. It really couldn't be more readily available...
The pizza here is amazing
Aside from the inconsistencies what else is deterring you from using it? I too can confirm that I've noted different ethanol content at different stations while I was there. I test my fuel every time before I fill it up.
Between around November to March it was typically the winter blend with most stations testing out to around 70% which is similar to what we get in Massachusetts. But once they go back to the summer blend its typically around 80-85%. I just remember seeing them everywhere. I basically had my favorite station which I found to be consistent, still tested it every time as I always do but went there about 99% of the time.
And yes it's only 11am but I could go for a pie right about now
Aside from the inconsistencies, I don't like the idea of the e85 slipping past my piston rings and making it's way into the oil. I understand that oil changes will have to be more frequent when running e85, and I will be keeping on top of oil changes like a mad man regardless of the fuel being used... but I don't want to even take the chance.
aronjaskim
10
Apr 13, 2011 06:10 PM
JYD
33
Jan 10, 2011 07:46 AM
