Enlighten me please! clutch issue/trans issue?
Ive had my evo 8 03 gsr for about 2 thousand miles drivetrain mods include. CC stg 2 clutch and stage 2 buschur transfer case, so heres the issue, im not sure if this is a problem or not, pulling out of my driveway i stopped at the end put it in neutral, tried to put the car back into first and it wouldnt go (into any gear). Also when backing in my driveway (in reverse, i back into my garage then when i reach my stopping point i engaged the clutch and put my brakes to stop, with the clutch engaged still and my foot off the brakes the car still rolls back and i have to force my car out of reverse. Also my car will slowly move in 3rd and 4th with the clutch engaged, the clutch still grabs and its not slipping any ideas?
Also in 1st and 2nd rolling im hearing a slight metal clunking noise when i apply gas and let off, and at around 4 to 4500 rpms cruising at full boost i feel a slight vibration underneath my feet, (mind you i have both my tie arms the bolt underneath the downpipe off)
Forgot to mention i just did this and the issue is still there, i have no grinding and my clutch is still stiff and grabs great, im not sure if the clutch needs bled or i need a new clutch or i should say, screw the previous owners word and change the trans fluid. Thank you
Well it does matter when you are trying to ask for help, kind of confusing to read it the opposite way.
Are you sure you adjusted it correctly? It is important to do it correctly.
Might want to check your slave too, make sure it's moving when you push the pedal.
vaflyboi757
Dec 18, 2015 10:27 AM
MarkChamorro
Jul 14, 2012 10:20 PM
bnr34rb26dett
10
Jun 5, 2012 11:47 PM
