problems with knock
Old Jul 27, 2014 | 08:50 PM
sgambino92's Avatar
problems with knock
I am currently having a problem with knock, i think. I have the tephra mod set up for the check engine light to flash when knock is picked up. I cant even do a full pull without the check engine light flashing. The car runs pretty good other than when building boost the AFRs are super rich. I don't think its the tune because it never used to be this bad. I would get the occasional CEL flash, but not to the point where i cant even get a full pull in. There is no hesitation or sputtering as i am in boost during a pull. So my question is, could bad spark plugs cause the CEL to flash, or cause some knock? That, or maybe i am picking up some good old phantom knock? I have my fuel map and ignition map saved from ECUflash, if posting that would help?
Evo 9
gt30r
FIC 950s
Double Pumper
Kelford 272s
SparkTech COP
Stock ECU
Speed Density
Old Jul 29, 2014 | 10:34 AM
okevolutionVIII's Avatar
Please post a ignition and fuel map with a log or 2. Too rich can cause as much knock as too lean and bad spark plugs would be noticed during a WOT pull from ignition break up.
Old Jul 31, 2014 | 09:28 PM
sgambino92's Avatar
Can anyone assist me with posting my evoscan log??
Fuel Map
Ignition Map
tephra
Sep 13, 2021 01:07 AM
CtSilver03Evo
Cobb AccessPORT
Dec 14, 2016 12:54 PM
Seancj
Jul 2, 2015 06:22 AM
thedru13
Nov 3, 2014 08:58 AM
furiousd
Feb 27, 2010 06:28 AM
