fuel pressure issues
Old Aug 1, 2014 | 05:18 PM
evoyrrah's Avatar
hey guys...im having some fuel pressure issues. its abit flakey on idle, sometimes its at 35 psi sometimes 38 sometimes 40 sometimes 44.its on a stock reg with double pumper(walbro 255s) anyone seen this before? maybe have a clue where to look?
Old Aug 1, 2014 | 05:56 PM
meckert's Avatar
You having any drivability issues? Running lean/rich etc?
Old Aug 1, 2014 | 06:21 PM
evoyrrah's Avatar
its on open loop to see whats going on. it does lean out or go rich depending on pressure....but no divability issues tho
Old Aug 1, 2014 | 06:25 PM
Faisalm's Avatar
Are you running both pumps full-time? Or Hobbs switch?
Old Aug 1, 2014 | 06:32 PM
evoyrrah's Avatar
its on a hobbs switch sir
Old Aug 1, 2014 | 07:24 PM
Faisalm's Avatar
I purchased 4, yes 4, modded Walbro 255s of which 2 failed within 100-200 KMs, the other 2 were brand new and weren't pushing fuel out of the tank to begin with.
It would be more convenient and easier to narrow down where the issue lies if you have a fuel filter such as this one:
http://www.foreinnovations.com/product_p/16-900.htm
Having this with the pressure gauge would help identify if the severe pressure fluctuation is being caused upstream or downstream.
Now this will obviously aid in analyzing the issue, but most of us are just tired of spending more money.... I would suggest firstly checking everything again, then swap places of both pumps, i.e ignition pump gets installed to the hobbs switch and vice versa.
Check your fuel filter, possible clogging could cause fluctuations as well.
If all hope is lot, try an aftermarket fuel regulator + fuel rail.
Old Aug 1, 2014 | 07:36 PM
evoyrrah's Avatar
yeh that would be handy but alot of $$....swapping pumps is a really good idea as it will take 5 mins....thanks for the sugestion! ill give it a go
Old Aug 1, 2014 | 11:52 PM
evoyrrah's Avatar
Tried swapping ignition pump and no change..... Gotta be the reg playing up yeh?
Old Aug 2, 2014 | 12:23 AM
Faisalm's Avatar
That would be the most likely suspect.
hung861988
Feb 13, 2015 04:45 AM
evodrivesme
Aug 26, 2014 12:14 PM
zenkisilvia
Nov 15, 2013 01:14 AM
$MIVEC$
29
Apr 4, 2012 07:23 PM
hybrids14
23
Oct 5, 2005 11:14 AM
